Old 12-27-2011, 07:08 PM   #1
E36White
Question on E39 phone system
2002 530i with OEM phone system, but handset was missing when I bought the car, is there a way I can change that wire adapter to fit a Samsung phone while maintaining full functionality of the system (steering controls, charging etc..) ??
Before getting flamed, I ran a quick search but all suggestions pretty much came to retrofitting bluetooth adapters and I'm not really sure if that's what I want to do here..
feedback is appreciated.
E36White is offline   Reply With Quote
Old 01-04-2012, 10:05 AM   #2
E36White
anyone?
Old 01-04-2012, 02:06 PM   #3
No clue...
but is there even a way that you could use the phone system?
Old 01-04-2012, 02:12 PM   #4
E36White
no unless if I try to source a handset, but I think there were a few models offered with the E39 like siemens nokia and ericsson etc (as per realoem.com)...
so how do I know what originally came with my car? is there a way I can decode my vin maybe?
Old 03-06-2012, 06:49 PM   #5
Blue530
Did you put the VIN into realoem.com to see if it came to any conclusions?
As i bought my car used, I had BMW run my VIN (to check on some parts I was ordering) and the parts counter guy was nice enough to printout the vehicle information page, which included the entire list of factory installed options. Although there was nothing on there that indicated specific parts replacement numbers I wouldn't be surprised if they could give you that information.
Blue530 is offline   Reply With Quote
Old 03-07-2012, 06:13 AM   #6
Gamite
Gamite's Avatar
I think if you want to go with the cradle for your phone, it will still require you to use the bluetooth.
I did the bluetooth retrofit, and let me tell you its a pain in the ass. especially for us 2002. One harness you actually have to fabricate yourself and there's a button that doesn't exist anymore so you have to find an alternative.
www.gamite.net
Old 03-07-2012, 03:07 PM   #7
Can we get more info on this?
I've just been considering other aftermarket options such as dice/media bridge.
Old 03-09-2012, 04:03 PM   #8
Gamite
Gamite's Avatar
Terry it depends on the year. I did a lot of searching and googling to find out what to get. I can show you what I did, and we can compare, but from what I remember your harness is different from mine.
www.gamite.net
Old 04-20-2012, 11:38 PM   #9
mech9T8
mech9T8's Avatar
I'm about to try a bluetooth retrofit in my 2001 530i.
Hopefully all goes well. Got the TCU and ordering the other stuff I need.
I found PDF instructions that looked pretty straight forward.
I'll post it here when i can find it again.
mech9T8 is offline   Reply With Quote
Old 05-01-2012, 09:32 PM   #10
updates?
Old 05-02-2012, 07:47 AM   #11
E39M5
E39M5's Avatar
I could be wrong, but from the research I did, going the Dice route was easier, then you also have iPod integration.
2003 Topaz Blue 540iT - sold
2001 Bluewater Metallic M5 - sold
1965 MGB GT - sold
2002 Audi A6 2.7T - for sale
E39M5 is offline   Reply With Quote
Old 05-06-2012, 08:33 AM   #12
mech9T8
mech9T8's Avatar
For the life of me I can't find the link to that PDF.
I'm going to make a trip to the states in a month and just order/pick up all the parts from there...along with a few other goodies
Old 05-12-2012, 04:03 PM   #13
540guy
I could be wrong but oem phone system costs more, involves more work, and has fewer features in comparison to the aftermarket offerings. Doesn't seem worth it unless you're going for the pure oem everything image.
I'm personally using the dice mediabridge with bluetooth
540guy is offline   Reply With Quote
Old 07-06-2012, 12:12 PM   #14
mech9T8
mech9T8's Avatar
So I finally got around to installing everything and it worked great. Phone paired, phoenbook downloaded and was able to send and receive calls. VR was enabled so that is a bonus.
But, I can barely hear incoming calls and could not adjust the volume. After doing more research it looks like I may need a small amp to boost volume. No biggie.
Old 07-09-2013, 10:00 PM   #15
SFX Group
SFX Group's Avatar
www.bimmernav.com has the BMW ULF (Bluetooth / voice control) for the BMW with a Harness options for all BMWs.
Generally what ever system was fitted to the car is bespoke, so you wont be able to change the handset, however if you want steering wheel controls like it should then Bluetooth (ULF) would be the way to go, its a failry easy project but will need parts for the center armrest.
I am fitted SES, then the newer TCU for my E38 and will have video on what i did.
Many Thanks
Ashley
© Copyright 2015 - www.ashleygriffin.ca ::: Click to see my current second hand parts :::
::: My Videos :::
::: LED side indicators ::: Navigation Mk2 to Mk4 upgrade ::: Glovebox position damper ::: 740Li 2013 tour ::: Voice Control teaser trailer :::
>>> Click picture to see my car used on TV as the James Bond car <<<<
SFX Group is offline   Reply With Quote
