Old 04-25-2012, 05:29 PM   #16
5ABIVT
Cheap reliable fast.Pick2
Dont use WD 40. It's a water displacement liquid meaning it WILL dry out rubber and painted surfaces.
SImple green 2 parts water 1 simple green and a brush.
After but before i changed all the bolts and armor alled everything but still obvious.
5ABIVT is offline   Reply With Quote
Old 04-25-2012, 05:35 PM   #17
Robb
EX E30 M3 Owner
Robb's Avatar
I agree... WD40 should only be used to break down dried rustproofing or crusty stock on dirt ! Thats why I used it.
For all other engine cleaning, any engine spray or All purpose cleaner diluted with water would work fine.
BTW, 5ABIVT your engine bay was only dusty.. nowhere near as bad as mine was !
Robb is offline   Reply With Quote
Old 04-25-2012, 05:41 PM   #18
5ABIVT
I probably missed that on the rust proofing .. Wd40 will def help get rid of that stuff. I hate degreaser personally because it dries out rubber as well. I like to think of it as a cleaner for engine blocks only from the prehistoric carbureted days where there wasn't so much rubber and plastic underhood. Back then domestic car makers couldn't build a car right let alone valve cover gaskets etc that would leave oil all over the side of the block that would accumulate dirt and debris. Degreaser is good for that.
Old 04-25-2012, 05:45 PM   #19
5ABIVT
Btw nice job on the clean up !!
Old 04-30-2012, 07:50 AM   #20
lotp_e90
Originally Posted by Randy View Post
i dont believe it.
I can personally vouch for robb's EF (91 civic). One of the cleanest ones I've seen at a Torontocivicsclub meet. Robb I didnt know you were on here? I use to be part of tcc as well; 91ef
lotp_e90 is offline   Reply With Quote
Old 04-30-2012, 11:00 AM   #21
Robb
EX E30 M3 Owner
Robb's Avatar
Cool.
Yea I used to have an 89 M3.
