12-08-2011, 01:05 PM
#46
Car: e30 318iS w/M50TU
I'm sure there are others like this, but have a look:
http://www.lant-ins.ca/custom_wheel_plan.php
Their rates are really cheap if you and your vehicle qualify. Any others out there?
12-08-2011, 01:42 PM
#47
Car: S54
Insurance has no connection to the Drive Clean testing procedure.
12-08-2011, 02:43 PM
#48
Car: 91 318is,93 325is...
S54 hpf stage 3 e36 would be crazy!!!
12-08-2011, 02:45 PM
#49
Techno Viking
Car: S54 E36 M3
No way, their new twin turbo setup is insane. They actually make good torque! Its only for RHD cars but I see them making a LHD version soon.
12-08-2011, 05:56 PM
#50
For those interested, this is the message I got back from a rep about emissions tests for vehicles with a non stock motor swap:
A Hot Rod is defined as a motor vehicle that is 1999 or an older model, in which the original motor has been replaced with a motor of a type not installed by the manufacturer on that model year of motor vehicle.
For the vehicle to be a Hot Rod, “type” refers to either the manufacturer or the block size of the replacement engine. If the manufacturer of the replacement engine is the same and the block size was available in that model and year of that particular vehicle, the vehicle is NOT a hot rod. If there is no engine change, the vehicle is NOT a hot rod. It is the responsibility of the vehicle owner to provide sufficient evidence (eg. receipts, work orders) to the inspector (at the time of the Drive Clean inspection) that the original motor has been replaced with a motor of a type or block size not installed by the manufacturer on that model year of motor vehicle. Otherwise the vehicle is tested normally according to the model year of the vehicle chassis.
A Hot Rod will be tested using emission standards, which apply to pre 1980 model year and older vehicles, which have been adjusted to accommodate emissions from similar size vehicles including all older model year vehicles.
If I don’t hear back from you, I will assume that this answers your question and I will close your case accordingly. Please be assured that you can reopen this case any time if you need additional assistance by replying to this message.
Regards,
Customer Service Representative
Ontario Drive Clean Program
1-888-758-2999
12-09-2011, 12:17 PM
#51
Formerly Flav_cool
Car: '98 328is + '94 325i
Awesome, thanks!
1998 BMW 328is - summer
1994 BMW 325i - daily
1992 BMW 325i - totaled
1988 Mercedes Benz 190E 2.3-8V - sold
12-09-2011, 12:18 PM
#52
Car: 98 M3 99
well you are still going to have to notify your insurance comp that the motor has been changed, otherwise your policy could be deemed void.
I'm curious what the hit would be.
12-09-2011, 05:21 PM
#53
Car: 1992 325is
I second that. It’s always interesting to see how each insurance company will evaluate the risk on a swap like this. I’m willing to bet you would see some pretty big variance between companies.
Thats great in regards to emissions though. Leaves exhaust choice wide open.
12-09-2011, 06:30 PM
#54
JUICY J CAN'T
Car: S54 titties
^^his insurance may come out cheaper than a e36 M3, because as was mentioned in this thread, although driveclean and insurance are unrelated, they both have special cases for hotrods.
Most people who build hotrods take care of them, so the rating for that type of vehicle could surprise you. Stock E36's on the other hand are almost exclusively driven by young males, who beat the shit out of them and drive like idiots.
12-13-2011, 08:34 PM
#55
Techno Viking
Car: S54 E36 M3
did a little bit of work today. Went out to Maranello to grab some parts from Mike. I had to take a couple pics of these lol.
replaced the exhaust studs with the m50 ones. also blocked off the secondary air pump with a block of plate.
oil pan all cleaned up
bottom end is nice and clean too.
new AN fitting for steel line
the mess someone is going to have to deal with lol
12-13-2011, 09:18 PM
#56
CEL Magnet
Car: E36 328i
Is that a McLaren sitting out in the sun all day?!? I hope that is owned by someone...
12-13-2011, 09:35 PM
#57
Car: God's Chariot
What size did that AN fitting end up being?
12-13-2011, 09:47 PM
#58
Techno Viking
Car: S54 E36 M3
Alex Lipowich ended up measuring it out for me. It was an m12x1.5 to -6.
12-13-2011, 11:17 PM
#59
Car: 95 325i 4 door
owned by the mclaren dealer
12-15-2011, 02:45 PM
#60
Hatters gon Hatt
Car: 318is roadtriper
salt in the lot!!!!  awsome swap btw!
