Old 11-08-2011, 07:43 PM   #1
limenuke
Exhaust Rattle
http://www.youtube.com/watch?v=0QnkuNQqMfE
My car's been rattling at 30kmph+. Frined told me to get under my car and tap things with a mallet. Video is shot from directly behind the front passenger wheel, underneath the car. I hit the offending piece of metal (a large metal shell) a couple times with the mallet...and then I hit the exhaust pipes to demonstrate the overall noise. Lo and behold that thing around the exhaust system is loose. What is it / what can I do?
Also, the last part of the video shows my jack stands. That's the front cross member right ? Is it a good place to put my stands?
limenuke is offline   Reply With Quote
Old 11-08-2011, 08:38 PM   #2
pawcio
pawcio's Avatar
depends where it is. i've had a loose exhaust bracket that i just removed and didn't replace. whether or not that is a big deal i don't know. personally i don't think so. my car have a few exhaust brackets. sometimes they rust through, get loose and rattle. so i just took it off. now it no longer rattles. that was over a year ago now and its fine.
__
Old 11-08-2011, 09:44 PM   #3
limenuke
http://realoem.com/bmw/showparts.do?...53&hg=18&fg=10
The part I was tapping wiht my mallet were the pieces of metal on part 1... The sectioned portions immediately to the right of the label 1. They are loose.
Old 11-08-2011, 10:56 PM   #4
pawcio
pawcio's Avatar
^ are they the actual pieces that are rattling against each other? or is there something loose that may be rattling against them?
__
Old 11-08-2011, 11:18 PM   #5
limenuke
The actual pieces. They are loose on the tubes.
Old 11-09-2011, 03:34 AM   #6
doogee
doogee's Avatar
Those are the shields on the cats.
Dakar M3 Track Build Thread
Old 11-09-2011, 12:41 PM   #7
limenuke
Is there any easy fix or anything? Any ideas? How are they originally fitted ?
Old 11-09-2011, 01:10 PM   #8
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
I used an exhaust u-clamp to clam the "nose" of the shield firmly down, haven't had any rattles since (30k + of "spirited" driving through mostly bump roads on rubber band tires).
Old 11-09-2011, 04:22 PM   #9
SiR
Vtec just kicked in
just rip it off...
-||Old Crayons||-
Old 11-09-2011, 04:39 PM   #10
limenuke
One of those bad boys?
Old 11-10-2011, 12:00 PM   #11
Axxe
Axxe's Avatar
Yup. Cant remember the size though.
Old 11-10-2011, 01:35 PM   #12
yellowfever3
i usually re-weld them on if they arent too rotted
yellowfever3 is offline   Reply With Quote
Old 11-10-2011, 02:08 PM   #13
limenuke
By heat shield, you do mean the things actually attached to the piping right? Not the piece in this picture:
I'm referring to actually circular pieces of metal rattling around the exhaust/cat piping.
Old 11-10-2011, 02:44 PM   #14
MrRWD
Could it be the item circled. I've seen that bolt come loose, and the two pieces rattle at different RPM's/Engine Load.
MrRWD is offline   Reply With Quote
Old 11-10-2011, 03:52 PM   #15
limenuke
I believe its the pieces between the label 1 and label 16 - the two ribbed circular pieces on the main tube. They are loose.
