Old 09-25-2011, 05:17 PM   #1
limenuke
97 328i - Installing skirts + Hooking up 6 CD changers
My first problem - my OEM skirt is coming off because the plastic clips snapped. There are a few that weren't snapped. I tried to push the skirt into the clip (while both were still attached to car) which yielded only in snapping the clip.
So now, I wonder - what is the order of putting the skirt on the car? Do you put the clips on the skirt and then shove the clip's end into the green grommet mounted on the rocker? Or do you do mount the clip first and then attempt pitifully to shove the skirt into the clip ( this was what I did and I failed at it ).
Secondly, the previous owner of the car installed a decent alpine deck into the car. Unfortunately, it doesn't link up with the 6 CD changer. Does anyone know what I need to do to get the 6 CD changer to operate?
limenuke is offline   Reply With Quote
Old 09-27-2011, 11:07 PM   #2
Daneee
be cool
Daneee's Avatar
Send a message via MSN to Daneee
thats the only one way
you need to buy an OEM radio or buy a CD changer for the Alpine deck
suck the fish
Daneee is offline   Reply With Quote
Old 09-28-2011, 01:09 PM   #3
limenuke
Gotcha. I'll buy a couple of those clips then. How do I reinstall the rivets on the skirts? do I get my own rivets or just attempt to reuse them?
What do you mean CD changer for the alpine deck...can I not use the BMW CD changer?
Old 09-28-2011, 04:16 PM   #4
tehskeo
CEL Magnet
tehskeo's Avatar
Unfortunately no. The BMW changer uses the IBUS interface with is proprietary and only BMW factory headunits can communicate on it. The Alpine deck will likely be able to communicate with several different aftermarket changers. I have my changer sitting disconnected in my trunk because I have an Alpine deck as well.
Does the deck have USB input? That may be better anyway...
tehskeo is offline   Reply With Quote
Old 09-28-2011, 04:39 PM   #5
noodles101
ΛΦΕ
noodles101's Avatar
yeah USB ipod connection with alpine deck is alot better choice.
u can run the wire through the glove compartment OR right below your on board computer ( there is a hole already there)
