Old 09-03-2011, 04:06 PM   #1
spooling
E36 overheating with low oil pressure at idle
e36 m52:
after driving on a hot day i noticed the oil pressure light was on at idle (it would go away when I touch the gas).
Shortly after the engine temp started to rise.
Oil level and coolant level were fine.
Any suggestions where to start?
spooling is offline   Reply With Quote
Old 09-03-2011, 05:07 PM   #2
check for oil in your coolant, and coolant in your oil.
Old 09-03-2011, 05:25 PM   #3
noodles101
ΛΦΕ
noodles101's Avatar
just check all ur cooling system.
thermostat , water pump , etc.
Old 09-04-2011, 10:43 AM   #4
spooling
would a cooling system issue cause the low oil pressure light to come on?
Old 09-06-2011, 03:47 PM   #5
sb_600
sb_600's Avatar
could be a failing pump?
Shawn
sb_600 is online now   Reply With Quote
Old 09-06-2011, 03:58 PM   #6
spooling
i'll try running a pressure test on the cooling system.
Old 09-06-2011, 05:21 PM   #7
DR.ZED
The theory would be that the engine oil is getting too hot and thinning out dramatically.
If you have a water to oil, oil cooler then coolant circulates around a heat exchanger to cool the oil. THis means if you are overheating or getting very hot you actually end up heating up the oil instead of cooling it. If you have an air to oil cooler than make sure airflow isn't blocked to that heat exchanger (rad) on the front of the car.
If the oil is a thin viscoscity to begin with then you may just be on the threshold of low oil pressure on a hot day. The "dummy light" probably comes on under 10 psi oil pressure. Now this isn't going to kill the engine, but ofcourse you should now know that your oil is too thin and should go up to a higher second number viscoscity (like a 5w40 or 50).
Small block chevy's rule of thumb used to be 10 psi per 1000 rpm. It was damn scary seeing my LT1 in my Camaro sitting near the redline of oil pressure on a hot day, but it was okay.
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 09-07-2011, 01:56 PM   #8
spooling
Thanks Zed, I'll take a look when we have a nice day.
Old 09-08-2011, 08:44 PM   #9
dil
dil's Avatar
had this problem in my e36 only way i got it fixed and gone for good was headgasket but that may not be your problem
dil is offline   Reply With Quote
Old 09-13-2011, 10:16 AM   #10
spooling
I'm hoping its the cooling system. I was running 5-30 on a hot day. My car runs hot already since its boosted. There is no oil in coolant or coolant in oil and zero smoke from the car. It still runs great just hot.
I'll be checking this week when I get a chance.
Will update when issue is found.
Old 09-13-2011, 10:36 PM   #11
naui16865
What's the mileage on the car and is the cooling system orig?
I've had creeping engine temp probs in hot weather due to a siezed aux fan (98 M3). It's easy to check and an easy fix if found to be failed.
I've also had unexplained low oil pressure warning in hot weather at idle (same 98 M3 at about 240k Km). Changed oil pressure sensor to correct. Again, low cost, simple repair if found faulty.
The combination of a weak sensor and creeping engine temp will give low pressure warning. Recommend you confirm cooling system operation and correct sensor-operation before leaping to more complicated (expensive) fault-condition explanations.
naui16865 is offline   Reply With Quote
Old 09-21-2011, 12:41 PM   #12
spooling
Thanks everyone for all the responses.
I found the issue, my engine fan was on the way out. I will be replacing with an electric fan and the corresponding cooling upgrades (maybe even an oil cooler for my turbo ).
Old 09-21-2011, 08:51 PM   #13
BmW1819
what about the oil pressure??? cause the engine temp was to high ??
Old 09-22-2011, 05:31 PM   #14
spooling
yea exactly. The engine heat was thinning the oil. Not to mention it was an extremely hot day and I was downtown.
Old 09-22-2011, 06:53 PM   #15
BmW1819
yea it all makes sense what oil are u using??
