Originally Posted by Steve30
I think Doogee is running them on his m3 but it requires you to use the offset fcabs if I remember correctly.
- Sent from my iPhone using Tapatalk
He is running the Meyle HD control arms with offset solid lower control arm bushings (LCAs). They do NOT require you to run offset bushings on a non-M3, even though I chose to.
The Meyle HD control arms are the same geometry as the '95 M3 arms (which use offset bushing stock).
