Old 08-03-2011, 09:26 AM   #1
dcramer
RSM reinforcement plates
I just saw a picture of someone who mounted the plates on the top (inside the trunk) I mounted mine underneath the car, however I'm starting to think they should be mounted inside the trunk since there is already a heavy plate ( the RSM itself) underneath.
Where should they be ?
Old 08-03-2011, 09:43 AM   #2
It should be on top, it does nothing on the bottom, it's purpose is to spread the load of the nuts you have bolted on the top which only have a small amount of surface area, therefore the metal is more likely to tear. With the plates on the top, the load from the nuts are spread across a larger area reducing the chance that it will tear the metal.
Dare I squeeze
Old 08-03-2011, 09:44 AM   #3
dcramer
So now I see the point of the Rogue Engineering plates, much nicer to change your shocks
Old 08-03-2011, 11:09 AM   #4
Yes. but it also requires you to have Rogue Engineering RSMs or to remove the studs on the RSMs you have.
Goodluck dealing with Rogue, they are a pain in the ass when it comes to international orders, they want a wire transfer, and shipping is ridiculous. $40 for RSMs worth $99. Stupid practices like that, don't get my money.
Dare I squeeze
Old 08-03-2011, 11:11 AM   #5
dcramer
Well I wasn't about to change them, and as long as you don't drive in the winter it would be fine. Thanks for the heads up about Rogue though
