Old 07-21-2011, 03:26 PM   #1
noodles101
ΛΦΕ
noodles101's Avatar
check engine : brake circuit failure??
i got a check engine light...after i washed my car...
it says brake circuit failure??
but my brake lights perfectly fine at any position the light switch is at..
its a 1996 328is
weird. any1 know what the problem is?
not too worried because everything works okay. just the warning sign flashing at me everytime i start my car.....
Old 07-21-2011, 03:37 PM   #2
Ceeker
just run and drive the car and see after turning it on and of if it resets itself. Should be fine..ghost in the machine sort of thing.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 07-21-2011, 04:45 PM   #3
325isdan
When you put on the brakes are your brake lights lighting up?
325isdan is offline   Reply With Quote
Old 07-21-2011, 05:34 PM   #4
noodles101
ΛΦΕ
noodles101's Avatar
yup . they both light up.
DRL , middle notch , and full low beams notch.
brake lights all light up and also comes on when i press on the brakes.
i'll take ceekers advice...and just wait it out
Old 07-21-2011, 05:40 PM   #5
BmW1819
your brake light switch is on it's way out it's not the check engine light tho brake light circuit come on the OBC check engine is a totally different ball game
Old 07-21-2011, 05:50 PM   #6
noodles101
ΛΦΕ
noodles101's Avatar
^^^what is a brake light switch......? is this thing gunna be a pain in the ass to change? ...
Old 07-21-2011, 06:39 PM   #7
BmW1819
no not at all it's under the drivers kick panal part is not expensive . where do u live?? maybe i can give u a hand if am in the area next week
Old 07-21-2011, 08:00 PM   #8
Ceeker
Located behind the arm of the brake pedal. As you press down on the pedal it presses a plunger in; This plunger is part of the brake switch.
Old 07-27-2011, 09:03 AM   #9
dcramer
I happen to have a brake light switch I never installed, cant return it so make me an offer
Old 07-27-2011, 09:07 AM   #10
SiR
Vtec just kicked in
http://www.pelicanparts.com/bmw/tech...ake_Switch.htm
-||Old Crayons||-
Old 07-27-2011, 07:34 PM   #11
325isdan
The brake switch isn't hard to replace but a major pain the ass to do.
Old 07-28-2011, 08:11 AM   #12
A.K.A. Blackout
BLACKOUT
A.K.A. Blackout's Avatar
I just ordered 2 switches from E-bay as mine went for the second time. Common issue on these E36's... Dealer wants $56 for the switch...
A.K.A. Blackout
A.K.A. Blackout is offline   Reply With Quote
Old 07-28-2011, 01:23 PM   #13
325isdan
www.autopartsway.ca I believe it is $12. OEM
Old 07-28-2011, 01:32 PM   #14
dcramer
Just checked, $25
Old 07-28-2011, 06:58 PM   #15
noodles101
ΛΦΕ
noodles101's Avatar
ya ....i thought i was lucky because the warning went off for a week or two...
but it came back again today....i guesss i'll have to change thisss...lol but i have no idea where it is or how to change this..LOL ..
