Old 06-27-2011, 01:54 PM   #1
cornflakecwl
cornflakecwl's Avatar
Anyone done heater core on e34?
Replaced every heater/coolant hose on my car when it overheated this weekend, found out it's not there, it's either the aux water pump/housing or the heater core (water coming from frame rail but interior of car not wet at all). Bypassed both and unplugged the pump for now, when I get back from my honeymoon in a few weeks, I'll hook them both back up and figure out where the coolant is actually coming from. Just wondering if anyone has done the heater core in an e34 and how bad it is. I'd prefer to fix it myself (gonna wait till prob sept as I wo't need heat until then) but if it's only a $300-$400 job i may pay someone to do it. TIA.
95 525i 5 spd - WIP
cornflakecwl is offline   Reply With Quote
Old 06-27-2011, 02:47 PM   #2
Ceeker
ummm...I think the set up is the same as an e32 which means you are going to have to remove the HVAC system in order to get to it. This means-BIGJOB..which means $$$$. I remember the e32's coming for these and the techs had the whole interior apart just to get at it. However, I could be mistaken. :-) anyone want to chime in?
btw, the heater "tap" is what it's called was a common problem for e34 models. they usually malfunction/leak. No fluid in the cabin but external? then it can only be this.
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
1 90 325is white - keepin
1 87 325i vert -red - keepin
Ceeker is online now   Reply With Quote
Old 06-27-2011, 03:12 PM   #3
cornflakecwl
That was what I thought at first, but then I read that the heater box has drains in it? So the coolant wouldn't have made it to the interior. I guess I can order the heater valve seeing as it's only like $150 and since it's a relatively easy fix I can try that and see what happens. I just didn't see anthing more than a little bit of fluid in the area around/under the heater valve, but that doesn't mean it's not the problem. I'll try that first since I was going to replace it anyways when I did the heater core to elminate another possible breakage. After this pretty much the whole system has been done!! Good for another 5 years anyways...lol
95 525i 5 spd - WIP
Old 06-27-2011, 06:49 PM   #4
Nick_V
Nick_V's Avatar
You're gonna have to take the entire console out to do it with any ease. Not hard, just a lot of digging. I would set aside a whole Saturday and just go at it - barring any snags you should be able to get it done I would think.
Old 10-01-2011, 09:20 AM   #5
azzwot
i was there and i took pics, hope it helps a bit
http://www.bimmernut.com/forum/body-...il-repair.html
azzwot is offline   Reply With Quote
Old 10-01-2011, 09:49 AM   #6
BmW1819
u would see coolant coming from the middle of the car there is drains for the hear core. Do u have a pressure tester????
How much coolant are u losing??
Old 10-01-2011, 01:37 PM   #7
JINT
JINT's Avatar
if your windshield fogs up easy on the drivers side, than your heater core or the o-rings on the piping to the heater core are shot. This is probably the stupidest fix i've done. Really annoying and time consuming, but you should be able to get it done if your hands grow from the right spots.
1990 M5 Euro
You wash your car like it was your firstborn child, you tend to its needs like it was your own body, you protect it like it's your family, then you drive it like you stole it
Old 10-04-2011, 11:47 AM   #8
Bavaria
Southern Beirut
Bavaria's Avatar
Send a message via MSN to Bavaria Send a message via Yahoo to Bavaria
this might help, if you got IHKA
http://forums.bimmerforums.com/forum....php?t=1328893
Bavaria is offline   Reply With Quote
Old 10-12-2011, 10:02 AM   #9
cornflakecwl
Thanks guys, it ended up just being the secondary water pump!! I replaced the heater valve and it was still leaking, bypassed the secondary pump and everything is good to go. Glad I don't have to do the heater core, that is now the last piece of the cooling system left to be changed.
95 525i 5 spd - WIP
Old 03-01-2013, 09:33 PM   #10
alex a
2nd generation///
easy job ive done it on my old 540 and tons of others pull centre of dash and centre console out make sure u replace the seals and don't crimp the o-ring or you'll be doing it again.........
alex a is offline   Reply With Quote
