Old 01-24-2011, 09:22 PM   #1
d.maczko
Cool unloading turbo m20 stuff
I am planning an engine swap so all of my m20 turbo stuff will be for sale.
I have a running turbo car, so everything you could imagine for a running car.
ebay manifold modified for 38mm external waste gate
ebay intercooler 24x12x3
3" downpipe with provision for waste gate to dump
holset h1e 18^cm3
-4an feed line, -10an drain line
welded oil pan for turbo drain
fittings for oil feed from pressure port on block
black powder coated charge piping and couplers
HKS ssqv bov
MS 2.2 with waste spark, GM coils, MSD wires
boost, oil press, water temp, egt pro sport gauges
.140 MLS headgasket
metric blue head bolts
would like to sell as a whole but will part out most likely
all parts are still on the car but will take apart as stuff sells
dont be afraid to pm me to ask anything
d.maczko is offline   Reply With Quote
Old 01-26-2011, 02:22 PM   #2
d.maczko
Cool
ebay manifold modified for 38mm external waste gate. 350
ebay intercooler 18x12x3 80
3" downpipe with provision for waste gate to dump 100
holset h1e 18^cm3 300
-4an feed line, -10an drain line 80
welded oil pan for turbo drain 250
fittings for oil feed from pressure port on block 10
black powder coated charge piping and couplers 100
HKS ssqv bov 25
MS 2.2 with waste spark, GM coils, MSD wires 300
boost, oil press, water temp, egt pro sport gauges 120
.140 MLS headgasket 100
metric blue head bolts 40
edit: will be adding more parts later today
I should mention the MS is a plug and play unit made by rs4pro
all you need to do is wire up the IAT
few other parts
B&M oil cooler, SS lines and nec fittings to use with factory oil filter housing 250
adjustable FPR, bolts into stock fuel rail, looks identical to stock unit. 50
Old 01-26-2011, 02:25 PM   #3
d.maczko
Old 03-18-2011, 05:33 PM   #4
hazy
You have PM
hazy is offline   Reply With Quote
Old 04-13-2011, 12:28 AM   #5
DIY
Permanently Dirty
DIY's Avatar
PM'd
Old 05-10-2011, 10:54 AM   #6
iverson03tj
pmed
e30 325ic -
PREVIOUS CARS
'01 Audi A4 B5
'96 Civic B16
'95 Acura Legend Type II
'97 Euro Estroil E36 M3 Vert
Old 05-15-2011, 06:34 PM   #7
d.maczko
all parts are out.
MLS and metric blues not available.
Also injectors are gone and oil feel/drain lines gone.
heres the new bay picture:
Old 06-09-2011, 05:55 PM   #8
Yamahammer
Warlock of the century
Yamahammer's Avatar
pm'd
Yamahammer is online now   Reply With Quote
Old 07-06-2011, 10:27 PM   #9
chapellej
that looks like a 2jz engine..........
chapellej is offline   Reply With Quote
Old 07-18-2011, 10:37 PM   #10
d.maczko
you would be correct.
I find myself having less and less time to work on it and get it running though.
Old 02-02-2012, 11:04 AM   #11
The Twin
The Twin's Avatar
interested in HKS SSQV and a couple other things...can't seem to be able to PM you.
please contact me via PM
The Twin is offline   Reply With Quote
Old 02-09-2012, 09:46 PM   #12
flex 54
Hi Send me your contact info flexr23@hotmail.com
flex 54 is offline   Reply With Quote
Old 02-12-2012, 07:32 AM   #13
flex 54
must not be check e-mail???
Old 02-19-2012, 02:54 PM   #14
xmedina
very intrested in MS email me at xmedina9705@yahoo.com
xmedina is offline   Reply With Quote
