Old 01-08-2011, 01:28 AM   #16
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Bimmerspecialist.com is your friend.
Old 01-10-2011, 11:07 AM   #17
TheMadChigga
Taiwan Panda Racing Unit.
TheMadChigga's Avatar
Send a message via ICQ to TheMadChigga Send a message via AIM to TheMadChigga Send a message via MSN to TheMadChigga
They got pretty good prices!
don't get too down about it, in winter time after prolonged driving, my car will tell me check coolant level, but after the car cooled down, all the coolant appears again, and I've bled the system a few times already.
Not to mention my car misfires ONLY at a specific intersection around my house when turning right, not anywhere else, but only there, can be any day, any time, any amount of gas, any gear, any speed, and only there, only turning right.
Volvo project
E39 project
Old 01-10-2011, 05:38 PM   #18
carjoe
carjoe's Avatar
Screwy.
I never checked bimmerspecialist but he's always higher when I check online. Same with Corner 73. I checked 3 places, NAPA, Autopartsway and rockauto. The downside is that I now have to wait for the parts.
93 325is - sold!
2000 540ia- sold!
Old 01-10-2011, 06:45 PM   #19
MLue1
MLue1's Avatar
In emergencies I've gotten parts from Pelican Parts within 24 hours. I over night the parts to Can Am Mailbox then drive down and pick em up. The savings are still substancial than buying from a Dealer.
Mark
'99 E39 540iT
Old 01-10-2011, 09:03 PM   #20
Oyster
Send a message via MSN to Oyster
Originally Posted by carjoe View Post
Rear ball joint, I think.
Needs struts/shocks.
Rear brakes.
Best part-Still leaking oil. I have no idea from where anymore. I did both VCG's, VANOS solenoid gaskets and upper timing covers.
Like I said, love it but can't afford the downtime.
We'll see waht happens after the coil gets swapped.
I was hopign the parts would be here for the weekend but alas, looks like Monday. That's the price you pay for not wanting to pay through the ass. NAPA wanted $240 per coil. I didn't even bother checking the dealer and Rockauto was $48 for Bosch with the boot. I wanted to see what Jared had but he's always over a week for delivery...
what mileage are you at?
I overhaul my whole suspension with oem sport and 1 front control arm + labour = $3200
Oyster is offline   Reply With Quote
Old 01-10-2011, 10:44 PM   #21
carjoe
carjoe's Avatar
I'm at 177k. I don't mind maintenance, it's the unscheduled downtime I can't deal with...
What exactly did you for the overhaul?
93 325is - sold!
2000 540ia- sold!
Old 01-13-2011, 04:53 PM   #22
carjoe
carjoe's Avatar
Yay. Replaced coil 1 and 2. Still running like a bag of crap.
Codes come back
P1341-multiple cylinder misfire
P1343-misfire cylinder 1 w/ fuel cut off
P1345-misfire cylinder 2 w/ fuel cut off
P1351-misfire cylinder 5 w/ fuel cut off
Fudge. I guess cyl 5. needs a coil too? I'll swap them around but damn, damn, damn.
93 325is - sold!
2000 540ia- sold!
Old 01-13-2011, 06:06 PM   #23
Oyster
last year, I ordered the plugs and all 8 of the coils to replace as preventive measure.
This year, I had the whole front and back suspsension replaced with OEM parts from Tisher.
Got piece of mind now
Old 01-13-2011, 07:03 PM   #24
MLue1
MLue1's Avatar
Codes come back
Crap, sorry man I feel your pain, all three coils can't have gone bad all at once, what are the odds.
When I troubleshooted a misfire in my P-car I used a temp gun that I bought from Canadian Tire to take the temp at the header,... I was able to identify the problem cylinder but as it turned out it was a plugged fuel injector was the culprit.
You can borrow my temp gun if you need to.
Mark
'99 E39 540iT
Old 01-13-2011, 07:11 PM   #25
carjoe
carjoe's Avatar
I'm not convinced this is a coil issue either. I've been swapping the coils and the codes didnt' change after clearing them. The codes arent' making any sense anymore...
Just to confirm, anyone know if the cylinders are numbered like a domestic? drivers side is 1-3-5-7, passenger side is 2-4-6-8?
*edit*OMG, I've been doing this wrong...http://forums.bimmerforums.com/forum....php?t=1181028
The cylinders are opposite to a domestic.
V8 M62, M62TU
Firing order...
1-5-4-8-6-3-7-2
4-------------8
3-------------7
2-------------6
1-------------5
Front of engine
93 325is - sold!
2000 540ia- sold!
Old 01-13-2011, 09:13 PM   #26
europrince
haha, that's what happens when you run an old, high maintenance bitch! I dropped mine a couple years ago. Money in the bank, I say!
Old 01-13-2011, 09:14 PM   #27
europrince
on an 11 year old car that's worth twice that....
Old 01-13-2011, 09:51 PM   #28
carjoe
carjoe's Avatar
I dont' get it. New coil, cleared the codes and the same coil is coming back as bad.
1341
1343
1349
1351
This doesn't make sense to me anymore. Could it be as simple as bad gas? The plugs are new from August, no oil leaks from the VCG's anymore....
I think I'm going to run some injector cleaner and just drive the piss out of it with different gas from the usual station.
93 325is - sold!
2000 540ia- sold!
Old 01-13-2011, 10:39 PM   #29
BimmerGuys
BimmerGuys's Avatar
It looks like fuel prob, check the injector
BimmerGuys is offline   Reply With Quote
Old 01-13-2011, 11:09 PM   #30
carjoe
carjoe's Avatar
I just went through my original codes and I'm thinking this is a fuel issue too. Would a bad fuel pump give a code? A bad fuel filter would affect high RPM, not just idle.
This is driving me nuts....
93 325is - sold!
2000 540ia- sold!
