03-22-2011, 12:18 AM
#46
Car: '95 Boston M3
wow shows how similar Laguna and Boston are, AGREE on the santa hat part... don't forget santa has to hand out gifts...
1995 US-Spec Boston Green M3
18x8.5 MK Motorsport MK1's, BavAuto F+R Strut Braces
UUC System U Catback
03-22-2011, 12:20 AM
#47
BMW Tuner
Car: BMW 330CI
Hey Santa, drop a e30 in my lane way right meow!!
03-22-2011, 01:51 AM
#48
Car: e30 with e91 beater
SB doles out liberal amounts of whoop-ass at autox every week he's there from what I've seen.
03-22-2011, 02:02 AM
#49
BMW Tuner
Car: BMW 330CI
Thank god he put in a racing seat for the ride a long's... GOD DAMN! I hope I fit hahaha
03-22-2011, 08:20 AM
#50
Car: e36 M52 330i
haha Bear we already gave you a motor - it's up to you to find the car
The competition is going to be tough this year - Chris phoned me last night and gave me *bad* news - apparently he's coming to party in B-class with us... and he's going to have a sweet suspension setup :S. And then there's Jamie... and then last year's AutoX champ, some S2000s.... it's gonna be fun
03-28-2011, 09:18 AM
#51
Car: e36 M52 330i
It was a busy weekend again!
I set out to stength test the brackets I welded for the 5-point harnesses. I figured if I could pick up the car by the brackets, they should be strong enough. I chained the engine crane to the brackets and lifted the car until two wheels were off the ground. They didn't move one bit
After that, Chris and I succeeded in pulling the M50 out. All that's left is to clean up the engine bay a bit, bolt stuff onto the new engine, and then it will be ready to drop in.
03-28-2011, 11:21 AM
#52
BMW Tuner
Car: BMW 330CI
03-28-2011, 11:27 AM
#53
Car: 2010 Mazdaspeed3
When do you think you'll be back out on the road? Before our spring cruise right?
03-28-2011, 12:52 PM
#54
Car: e36 M52 330i
Steve this car will never see the road
but the e46 is good to go (minus an exhaust leak that I need to take care of - just need to replace some hardware and the gaskets)
03-28-2011, 01:17 PM
#55
AWWW  I was hoping for some fun! I might see if I can try out the speed3 on the autoX track just once to see what I can do and what the Mazda brand can bring to the table.
03-29-2011, 05:09 PM
#56
Car: '95 Boston M3
I'm sure the speed3 would be a very capable autox car!
03-29-2011, 05:40 PM
#57
I dunno  It goes like stink and brake and corners pretty decent. If it was RWD, I'm sure it would be more capable because of the torque steer but you just need big pipes like myself and it doesn't really bother me.
03-29-2011, 10:46 PM
#58
Car: e36 M52 330i
I'm sure the speed3 would be sweet. Just put a big rear bar on it to get it to rotate and you'll do fine
03-29-2011, 11:20 PM
#59
ROFL! also put those trolley wheels on so I can have people run behind it so it can turn on a dime!
04-11-2011, 10:14 AM
#60
Car: e36 M52 330i
I bit of progress was made this weekend, but not as much as I had hoped.
I had the day off work on friday and the plan was to get the engine back in the car. I had removed the front subframe earlier in the week, welded in engine mount reinforcement tabs, and repainted it. I then reinstalled it with new M3 control arms to increase the caster. I also took the opportunity to clean the steering rack and install new inner & outer tie rods (old ones were seized). My new solid AKG engine & transmission mounts had arrived last week as well and they were bolted on too.
The engine was pretty much ready for the flywheel/clutch/transmission. After installing the flywheel, thankfully I checked and noticed that the crankshaft didn't have a pilot bearing! It wasn't in stock at Otto's BMW so the engine work was stopped there for the weekend. I still got a few other things done though, and I helped Chris with his engine (my old M50NV) - you can see what we did (if you haven't already) in his build thread. That engine is in such better shape than my M52 was when I pulled it apart!
I NEED to have the engine running next weekend. The weekend after that is Easter, and the weekend after that is the test and tune at Picton! It's going to be close. I'll be spending evenings this week installing the engine, transmission and exhaust.
