Go Back   maXbimmer Forums > Specific Regional Topics > Quebec/Gatineau/Ottawa
Old 11-07-2010, 08:46 PM   #1
sb_600
sb_600's Avatar
Shawn's track car project (e36 M52 325i)
Hey all,
At Bear's request, I'm cross-posting this from the track forum:
http://www.maxbimmer.com/forums/showthread.php?t=134006
This weekend, Bear came over and with a couple buddies, we stripped the M52 that I'll be putting in the car this winter completely. It looks like it was in rough shape, and was due for a freshening up. I'm pretty exited - everything went really well except we snapped the plastic primary chain guide.
Here's a link to the writeup on our website:
http://www.eurotrashmotorsports.com/?p=1598
and a link to the gallery:
http://www.eurotrashmotorsports.com/...m=4&gallery=11
If you guys would like, I can keep updating with my winter progess.
Let me know what you think!
Shawn
sb_600 is online now   Reply With Quote
Old 11-07-2010, 09:02 PM   #2
ooOOOOooooooo...
Looks like this is going to be a lot of fun!!
Old 11-07-2010, 09:50 PM   #3
bmwconnect
BMW Tuner
bmwconnect's Avatar
This motor is no doubt going to take you to a whole new level at the autocross... glad I could be apart of it and can't wait to see what we can get out of her in terms of hp & torque
Old 11-08-2010, 09:43 AM   #4
sb_600
sb_600's Avatar
I'm very excited to see the car run next year - it's going to be pretty awwesome I think. Before the fun happens though, I have a lot of long nights ahead of me cleaning parts!
Shawn
Old 11-08-2010, 05:30 PM   #5
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
nice looking ride. should be sick once completed.
keep us updated.
bmdbley'sBro is online now   Reply With Quote
Old 11-10-2010, 11:04 AM   #6
sb_600
sb_600's Avatar
Last night i got the cam trays, crank, and head cleaned. More coming soon
There are a few pics on the site, as well as the before pics if you want to compare. For now, here's a teaser.
About 2L of Super clean later, TA DA:
Shawn
Old 11-10-2010, 11:05 AM   #7
bmwconnect
BMW Tuner
bmwconnect's Avatar
damn nice!!
Old 11-11-2010, 09:24 PM   #8
sb_600
sb_600's Avatar
Today, I went to Ogdensburg to pick up the new cams (from an S52 M3) - I laid the S52 and M52 cams side by side and it's easy to see why the M3 are an upgrade. The lobe profile is visually obviously different. After that, my buddy and I got pretty much all the parts clean. Only things left are the oil pan, oil filter housing, and the finishing touches on the pistons. Oh, and the lifters are soaking in diesel fuel overnight.
I'm going to take my block to Ackek tomorrow (on somerset)- they're charging me $80 for the cleaning, and $10/cylinder for deglazing (honing). I also may bring them my crank to have it balanced while i'm there.
I went crazy on one of the pistons today, and this is how it turned out :
Shawn
Old 11-12-2010, 01:36 AM   #9
bmwconnect
BMW Tuner
bmwconnect's Avatar
you are a cleaning machine!!
Old 11-18-2010, 03:09 PM   #10
sb_600
sb_600's Avatar
Well after spending hours cleaning all the pistons, I hear back from the machine shop that my cylinder bores are oval by 0.005", which means I need to oversize the pistons.
So it looks like new pistons will have to be ordered. I have two options: do a slight overbore and get an OEM replacement piston, or go big and bore to M3 spec, and get high compression pistons.
The machining costs are the same, so it comes down to piston costs. I think i'm going to go big - but my wallet isn't happy about it. I figure if I'm going to be putting in that much money, I might as well get some more power out of it!
The pistons I'm leaning towards are CP, with an 86.4mm bore, and 11.5:1 compression ratio. Should be fun to have an e36 330i track car
I also started cleaning out the interior a bit more - got rid of about another 5lbs of wiring, and started working on a seat template.
Shawn
Old 11-18-2010, 03:50 PM   #11
BigD
the misanthropist
BigD's Avatar
Hoping that I'm asking the obvious - the bores are oval with a torque plate on and the mains torqued down?
Old 11-18-2010, 04:20 PM   #12
sb_600
sb_600's Avatar
hmmm not sure - it was measured by a local engine machine shop. I'm assuming they did it right. I know that when we were taking the engine apart, we could wiggle some of the pistons within the cylinders...
Shawn
Old 11-18-2010, 05:28 PM   #13
BigD
the misanthropist
BigD's Avatar
Ask them to tell you their procedure for doing the check, don't mention a torque plate or anything else. I'd be surprised if they even have a torque plate for your engine. If they bore it without one then they will make it oval.
Old 11-18-2010, 05:55 PM   #14
sb_600
sb_600's Avatar
thanks for the info! I know the guy was saying that he's going to clamp the mains down for the boring - i'm just not sure if he did it for the check.
I'll look into it!
Shawn
Old 11-18-2010, 05:57 PM   #15
bmwconnect
BMW Tuner
bmwconnect's Avatar
glad you are taking the new piston route shawn I knew when I saw them rocking in the cylinder with that much play there was going to be problems
