Old 08-20-2010, 07:50 AM   #46
richie_s999
So thought I better update the thread with what's been going on....
Finally got the matching springs in the rear of the car, so now the car has proper
matched spring rates, and installed a used set of Boge rear shocks, and the cars feeling much better. The rear sub frame bushings are getting bad, so looking into some poly bushings and hoping to upgrade the rear control arms while I have it apart.
Also got a chip for the car, since I was so impressed by the Mark D chip I had in the e30, it was an easy decission on which chip to go with. Mark D's tunes are second to none, and must say I am more then impressed with his OBD1 chip for the 325is. The jump in torque is more then noticable through the entire rpm band, and the 7200 redline will be more then helpful at this weekends autocross.
Old 09-13-2010, 08:43 AM   #47
hosty
323i???
hosty's Avatar
awesome, car looks 100x better.
Keep it up
hosty is offline   Reply With Quote
Old 09-13-2010, 08:49 AM   #48
Ceeker
Nice to see you are still alive!!!! LOL
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
1 90 325is white - keepin
1 87 325i vert -red - keepin
Old 09-15-2010, 11:10 PM   #49
iverson03tj
are u planning to reinforce the subframe? because i was told that putting stiffer bushings would put alot of stress on it...unno if its true thou.
Old 09-16-2010, 11:40 AM   #50
richie_s999
Powerflex has both a street and race set of bushings and I decided to go with the street ones cause the car is my daily driver. I will be giving the subframe a good once over for any cracking or signs of wear. Eventually I will be welding in the reienforcements, but more worried right now about the spot where the mounting bolts attach to the floor getting messed up with worn bushings.
Even with rubber bushings, many people weld in reinforced plates on subfames. It is more from lateral forces on the subframe under heavey side load during cornering. The harder you can corner the greater the loads are which are more affected by suspension and tires then the bushings used.
On a side note, no more elephant ear mirrors, picked up a set of racing dynamic cup mirrors, was going to get M3 mirrors, but the RD mirrors le the car stand out and have a great look.
Old 09-25-2010, 11:27 AM   #51
richie_s999
Started on the rear sub frame job this week. Dropped the whole rearend out and 2 of the mounting points from the car floor came out with the subframe. Was kinda expecting this as it's common to happen.
So to fix this and prevent it from happening again, I've ordered the M3 reinforcement plates for the mounting points on the floor, Turner actually has a kit that also comes with sub frame and shock tower reinforcemnts so I figured might as well do it all while it's out.
Also ordered stainless steel brake lines from turner, I've got to drop the gas tank to weld in reinforcement plates so goint to replace all the lines while it's out.
When it's all said and done car will be solid and able to handle the track and autocross use planned for it.
Anyone who has an e36 they are tracking or driving very hard should look into installing the M3 plates !!!!
Old 09-25-2010, 06:57 PM   #52
iverson03tj
Good luck and please take a lot of pics if u can..
thank you n keep it up.
Old 09-28-2010, 09:28 AM   #53
richie_s999
Rearend removed, sub frame and suspension in good shaep, other then the sub frame bushings....power flex street poly will be used.....
pics show the 2 good mounting points on the underside...........BUT.........
Old 09-28-2010, 09:30 AM   #54
richie_s999
BUT here are the bad 2....... will be doing some welding and upgrading!!!!!!
Old 09-28-2010, 09:56 AM   #55
richie_s999
here is a pick of the kit I ordered from Turner Motorsports to beef things up
Old 09-28-2010, 10:29 AM   #56
Those pics of giant holes where the subframe mounts up will probably make rudy reconsider buying an E36
Good luck, welding upside down is never fun lol
Old 09-28-2010, 01:39 PM   #57
Originally Posted by bullet ride View Post
those pics of giant holes where the subframe mounts up will probably make rudy reconsider buying an e36 :d
good luck, welding upside down is never fun lol
lol
Rippin' Proper | E30 | E36 | E36 M3 | E36 Ti |
Old 09-28-2010, 04:15 PM   #58
doogee
Stance is Gay.
doogee's Avatar
Thats why hes gonna get a euro M3
Dakar M3 Track Build Thread
Old 09-29-2010, 12:13 AM   #59
richie_s999
parts came in today from Turner Motorsports, was cheaper then i was expecting!!
SS brake line kit was $99.95
complete reinforcement kit was 212.75
shipping $16.68
duties on deleivery (UPS ) $69.78
BUT!!!!!!!
got a sales discount of $121.75!!!!!!!!!!!!!!!!!!!
total was $290 canadian with shiping and duties!!!!!!!!!!!
Dealer wanted over $200 just for the 4 floor reinforcement plates
Old 09-29-2010, 03:20 PM   #60
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
How did you get the discount? I sent you a PM regarding your SSK last week, haven't heard anything back. Looking for a detailed parts list of what's included and for what cost so that I know what I need to buy to complete my 5spd swap.
