05-04-2010, 01:41 PM
#1
Car: Gamitemobile
Looking to buy a 5 series, look here
E34: 1989 to 1995
Pre-Facelift 1989-1993
- 1989 -1991 came with US Spec projector headlights
- 1993 gets updated mirror style
Facelift 1994 - 1995
- All years came with US spec projector headlights
- Wider grill, M5 Side skirts
- Available models: 525i (2.5L M50), 530i (4.0L M60), 540i (4.0L M60)
- Interior door panels updated
Special Models
M5 - 1989-1992?
M540 - 1995 - This was a special edition that came to Canada instead of the M5, look for the plaque that will state which number out of 132 cars came.
Available options to look for
- Drop Down seats
Things to look for
- Rust at the bottom of the doors
- Thrust arms rattle, causing vibrations at 55mph (88km/h)
- M60 motors suffer from nikalsil problems, lower quality gas ate away at the sleeves of the cylinders, the engine should go for a compression check before purchasing.
- M60 - power steering leaks, driver's side motor mounts, valley pan gasket (mysterious coolant leaks), timing cover gaskets, valve cover gaskets, rear main seal
- M60 Oil pump bolts/mounting nuts notoriously rattle loose and end up in laying in the pan.
E39: 1996 to 2003
Pre-Facelift 1996 - 2000
- Available models: 528i (2.8L M52), 540i (4.4L M62)
Facelift 2001 - 2003
- Available Models: 525i (2.5L M54), 530i (3.0L M54), 540i (4.4L M62)
- Updated headlights/taillights
- Updated steering wheel
Special Models:
- M5 (Headliner was upgraded from black felt to alacantera for the facelift as well as updated cluster steering and steering wheel.)
Things to look for:
- M62 motor mounts tend to leak and get soft, this causes the rad neck to crack and eventually break off.
- LCD pixels in the lower display in the cluster almost always go, this is a very common occurance in E39's.
E60: 2004 to current
F10: Future
Feel free to add to this list, I will add them as you guys go along.
05-04-2010, 03:59 PM
#2
Car: E34iT, E30i
E34 M60 - power steering leaks, driver's side motor mounts, valley pan gasket (mysterious coolant leaks), timing cover gaskets, valve cover gaskets, rear main seal, lol etc.... can be expensive and a bitch to fix all that crap so make sure you know what's been done, cause if not, these things WILL leak eventually.
Reason: forgot some stuff...
05-04-2010, 05:52 PM
#3
Car: Gamitemobile
are these problems specific to you, or do you know for a fact that it will happen to most cars?
Every BMW power steering leaks, so I didn't put that in.
05-04-2010, 06:31 PM
#4
Car: E34iT, E30i
yes, all of these are well documented as being specific M60 problems.
05-04-2010, 06:35 PM
#5
Car: E34iT, E30i
I forgot a really important one that's also M60-specific: Oil pump bolts/mounting nuts notoriously rattle loose and end up in laying in the pan. This definitely happens to most cars...
08-15-2011, 09:00 AM
#6
Car: 1994 M3 Eurospec #25
Correct me if I'm wrong, but I'm pretty sure there were only 32 M540's imported into Canada - not 132, making it one of the rarest out there.
08-15-2011, 11:32 AM
#7
Car: 2 X BMW M5
Correct.
www.enthusiastauto.caContact if you are looking for a car
His--2000 BMW ///M5 .:Jet Black on Black:. Individual - Style 65 Wheels; 9.5" Square Set up;275 Tires;10mm/3mm Spacers; Black Kidneys;Muffler Delete; 3.5" Dual Tips; Beast Power Sway Brackets; "Dinan" Ducts; E60 SSK; BC Coils
Hers--2000 BMW ///M5 .:Avus Blue on Grey/Black:. '01 Exterior Upgrades; E60 SSK
08-21-2011, 03:27 PM
#8
Car: 2008 535i
FYI , the latest Bimmer mag has a great article on buying a used E60.
good thing I already read up on most things before buying my CPO 535i
01-07-2013, 02:27 PM
#9
Car: E90 335
04-05-2013, 07:06 PM
#10
Car: E46 330ci
Hope someone can shed some light on this. I was looking at a E34 and I noticed on the back it said AC Schnitzer. My google search has come up empty.
05-07-2013, 11:55 AM
#11
Car: 03 540i M Tech
And only 16 were 6 spd Manual, and I have one of those 16
