Old 10-05-2009, 09:41 AM   #1
cormier
cormier's Avatar
DME question
Hey all,
Ive searched far and wide for this info -- wondering if someone can help me out
Preparing for my S52 swap, got a hold of a Siemens DME with the engine... I can only find info on the Bosch DMEs though. Anyoneknow if the Harness differs at all between the two brands? Whats the actual difference between the Siemens/Bosch models and what cars did each come in?
I found a few places that listed late 90s as the switch over-point from Bosch to Siemens -- Just want to make sure that this DME will work with my S52 engine
Any help would be hot -- thanks!
Old 10-05-2009, 09:58 AM   #2
ScotcH
Well, I assume you're stuffing this into your e30? If so, you need to get an OBDI harness and computer (which means Bosch 413 or 506). The Siemens is OBDII, so no good for you. The engine wiring harness is different, so you need that as well (and 325 or 95 M3 harness will do). You will also need the crank sensor, cam sensor, and knock sensors from OBDI engine.
Old 10-05-2009, 01:31 PM   #3
cormier
cormier's Avatar
Whats wrong with just dropping an OBD II swap in? I already have OBD II harness and sensors, only issue would be EWS...I got the M50 manifold anyways which from what I hear is the majority of the benefit from running OBD I. But I believe you answered my original question anyways , If Im running OBDII, Siemens DME will work fine with the EWS disabled.
Now are the software tunes the same between Bosch and Siemens?
