Old 09-20-2009, 09:44 PM   #1
Pongs318
Style 5
I have staggered style five rims 8"/9" rears tryed it on my e36
tires on rigth now is 235/45 and 255/40 and it's rubbing you think
it's going to be ok to put on 205/40/17 all around or just put the 235/45
at the rear thanks in advance
Pongs318 is offline   Reply With Quote
Old 09-21-2009, 08:37 AM   #2
LondonWraith
LondonWraith's Avatar
pretty sure on e36 you can't run a 9" rim on the back without a high (is this right?) offset.
LondonWraith is offline   Reply With Quote
Old 09-21-2009, 12:57 PM   #3
Pongs318
e39 offset,but my rear have the stock springs and front is lowered,but i think i'll try and see what it looks like with the rear is lowered with the 9" rears
Old 09-21-2009, 01:10 PM   #4
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
With e39 tires you will have to run skinny tires. That is, 215s or 205s. BTW the proper tire size is 235/40/17 not 45...
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 09-21-2009, 02:49 PM   #5
Pongs318
thanks,does anybody have a pix of style 5s on e36,i think im going with 205 40 17s,thanks
Old 09-21-2009, 08:55 PM   #6
I have the staggered 18" E38 ones on my car.
We pulled (flared) the rear fenders for clearance. It was the only way, as the RIM was rubbing. With how severe that was, I'm not sure that the 1" smaller diameter is going to prevent you from having to do the same.
Old 09-21-2009, 09:08 PM   #7
Pongs318
you drop the rear's or stock spring's,how much did you pull the rear fender's out,will fender rooling do the trick thanks
Old 09-21-2009, 09:11 PM   #8
Pongs318
oh and thanks for the pix,what tire size you running thanks
Old 09-22-2009, 08:19 AM   #9
The rear is only about .5" lower than stock. But I have a '95 US Spec M3, my stock rear is a lot lower than yours.
The rear fenders are pulled out pretty severely, basically the factory quarter edge angles down to 90 degrees flat towards the ground, while mine continues the outward slope of the higher part. Probably a 10-15mm difference at the bottom of the fender edge. 215/35/18 tires.
Old 09-23-2009, 05:57 PM   #10
344i
344i's Avatar
^ As Jay said.
I have 8" wide style 5s in 17". they need 205 40r17 to clear with no fender pulling or rolling. Thats a super skinny tire for our roads. I am going to try 215s next year.
344i is offline   Reply With Quote
Old 09-24-2009, 12:29 AM   #11
Dr. Flyview
"Mint"
^^ 205's are not super skinny, they are just as skinny as the stock 205/60/15... But then again I'd much rather get real style 5s in the proper e36 offset, and run 235/40/17
sold
Old 09-24-2009, 09:16 PM   #12
344i
344i's Avatar
205 40r17 on a 8inch wide rim is super skinny.
Old 09-24-2009, 11:51 PM   #13
Pongs318
yeap 205 40 is ok want to go 195 at the fronts,its just that the wheel gap is the same on 344i 's pix even when its lowered will try to post pix
Old 09-25-2009, 01:02 AM   #14
344i
344i's Avatar
i have 205 40r17. My car is lowered. The tire is too skinny!!!
You need minimum 215s, sorry. Also, 205s have crappy stability, too thin.
I suggest you get 215s with all the holes on our roads.
Old 09-25-2009, 05:49 PM   #15
HuD 91gt
I've got 16" E39(ET20) Style 29's on my E36 with 205's, and they rub, even with a slight fender roll! But they look good Bilstein PSS Coilovers at their max height.
HuD 91gt is offline   Reply With Quote
