Go Back   maXbimmer Forums > Misc > FAQ
Old 02-23-2003, 05:10 AM   #1
Bill Gates
Bill Gates's Avatar
Send a message via MSN to Bill Gates
How to replace bulbs behind cluster
Tools required:
1) long philips screwdriver
2) small flat head screwdriver (to pry out the cluster)
3) piece of cloth to protect your cluster from scratching (very important)
Step 1) Remove both screws
Bill Gates is offline   Reply With Quote
Old 02-23-2003, 05:12 AM   #2
Bill Gates
Bill Gates's Avatar
use a long screw driver...
Old 02-23-2003, 05:14 AM   #3
Bill Gates
Bill Gates's Avatar
Step 2: insert a small flathead screwdriver to pry the cluster. be gentle!
Old 02-23-2003, 05:21 AM   #4
Bill Gates
Bill Gates's Avatar
Step 3: this is the tricky part. place a piece of soft cloth on the steering wheel to prevent any scratches to the cluster. pull the cluster out towards the passenger seat. at first, it will seem impossible, but be patient. DON'T yank or force it out, be careful not to pull the cables behind the cluster.
Old 02-23-2003, 05:24 AM   #5
Bill Gates
Bill Gates's Avatar
keep pulling...
Old 02-23-2003, 05:25 AM   #6
Bill Gates
Bill Gates's Avatar
keep pulling but start pointing the cluster upwards...
Old 02-23-2003, 05:27 AM   #7
Bill Gates
Bill Gates's Avatar
Step 4: this is the final position of the cluster before removing the connectors.
Old 02-23-2003, 05:30 AM   #8
Bill Gates
Bill Gates's Avatar
Step 5: locate the 3 connectors.
Old 02-23-2003, 05:33 AM   #9
Bill Gates
Bill Gates's Avatar
Step 6: use the small flat head screwdriver to push down the notch to open the latch. (do this for all connectors)
Old 02-23-2003, 05:36 AM   #10
Bill Gates
Bill Gates's Avatar
the open latch should look like this.
Old 02-23-2003, 05:40 AM   #11
Bill Gates
Bill Gates's Avatar
Step 7: after u unlatch and pull out all the connectors, slowly remove the cluster.
locate the bulb you need to replace, and visit your closest dealer. bulbs are very cheap, .60cents each or something.
just remember not to touch the bulb with your bare fingers.
replace the bulb and re-connect all the connectors and don't forget to close the latch.
any questions, just pm me.
good luck.
Old 02-23-2003, 12:59 PM   #12
Harry
Nice write-up Mr. gates.. Thanks.
Harry is offline   Reply With Quote
Old 02-23-2003, 01:58 PM   #13
Bill Gates
Bill Gates's Avatar
Thanks Harry. this job was very easy to do. and trust me, i'm no mechanic!
Old 04-01-2003, 04:30 PM   #14
Mikester
7th Gear Member
Mikester's Avatar
Send a message via ICQ to Mikester
what color did you do it BG?
Mikester is offline   Reply With Quote
Old 04-02-2003, 12:07 PM   #15
SebSter
SebSter's Avatar
what extra steps do u need if u wanna change the dials inside
SebSter is offline   Reply With Quote
