Old 03-14-2008, 12:45 PM   #1
shawno371
Big Problem Need All Advice!!!!!!!!
Hey everyone this is the problem I have been trouble shooting for a month.
I have a 92 325i 5 spd and there was a little fire under the hood i got it out in time very minor damage. I bought a parts car thats a 92 325i auto I swapped out everything under the hood but the actual engine. Also the wiring harness, then i find out after i put it all back to getter that, the engine in the car is a vanos so at one point in time some did a engine swap.
So i think the engine might be a 94 . was 94 when they came out in the 325?
The car rolls over i have spark and fuel but it wont kick at all, I have been doing so much research and i found that people say a non-vanos harness will not work a vanos engine if some on could tell me that its for sure then im in need of a vanoe engine wiring harness.
THanks Shawn
shawno371 is offline   Reply With Quote
Old 03-14-2008, 12:47 PM   #2
Boots R
Boots, not boost
Boots R's Avatar
Vanos came out for e36 in 93.
Old 03-14-2008, 01:57 PM   #3
Dr. Flyview
Formerly Flav_cool
Dr. Flyview's Avatar
Send a message via MSN to Dr. Flyview
Yes, I believe you need the wiring harness for the vanos engine.
1998 BMW 328is - summer
1994 BMW 325i - daily
1992 BMW 325i - totaled
sold
Dr. Flyview is online now   Reply With Quote
Old 03-14-2008, 02:46 PM   #4
ScotcH
And 413 DME
Old 03-14-2008, 02:59 PM   #5
shawno371
Oh i though vanos came out in 94 but if it did in 93 even better.
Does anyone know where i could find one.
Old 03-14-2008, 03:03 PM   #6
v_bimmer
Jailbait FTW
v_bimmer's Avatar
try calling Eurostyle, you can find his number in the sponsor section of this website!! He should have a harness, if not try bimmersport!!
Old 03-14-2008, 03:11 PM   #7
shawno371
Hey are all 325 92-99 engines M50 vanos and non vanos
Old 03-14-2008, 03:16 PM   #8
shawno371
Oh yea and one other thing my car is a 92 325i so OBD I right and it had a vanos engine in the car what would they have done to it to make it work. would it be converted to OBDII. What year did the OBDII come out on these cars
Old 03-14-2008, 03:42 PM   #9
Boots R
Boots, not boost
Boots R's Avatar
92 had no vanos
93 to 99 had vanos
92 - 95 : m50 (OBDI)
96 - 99 : m52 (OBDII)
Your previous car was a 92 so it would not have been converted to OBDII.
Old 03-14-2008, 10:39 PM   #10
shawno371
Are there any differences in the two harness OBD I and II so i can make sure im getting the right one and also how can u tell whether its standard or auto.
and also i think i discovered what engine is in my car its from a e34 525i, i found a vin on the ecu and it came up 92 525i. In my 92 325i now what kind of harness am i going to need.
Old 03-15-2008, 12:56 AM   #11
ScotcH
What model DME (ecu) do you have is it a 413 (the part number ends in 413)?
You need an ODB1 harness from a 93-95 325, as well as the 413 red label DME. Are you sure you got a vanos engine? How do you know?
Old 03-15-2008, 01:22 AM   #12
Eurostyle
Eurostyle's Avatar
Yes they are, the OBD 2 is almost worthless (eveybody needs OBD 1 for swaps) but i dont remember what the obvious differences are...The auto/5spd is very clear, the standard has one plug for a computer, and the auto has 2 (one for engine and one for transmission)...but it shouldnt be much of a problem, as you can use an auto on 5 spd (you just dont use one plug).
I think you should just swap the motor for the the non vanos one...
Eurostyle is online now   Reply With Quote
Old 03-15-2008, 11:33 AM   #13
shawno371
THe ecu that came with my car when i bought it came with a 413 ecu and my parts car is a 402. I checked the vin on the ecu it saying it form a 92 525i auto in my 325i 5 spd.
Can i get any harness from a OBDI 525 vanos or a 93-95 325i vanos will both harness work for my car.
My car has vanos from the hump on the top on the motor and my parts car doesnt have one.
I have the wiring form a non vanos in my car right now but it wont run but i have fuel and spark.
Old 03-15-2008, 01:43 PM   #14
shawno371
And What else do i need to run my vanos engine in my 92 i know about the harness and ecu but is there anything else thats different between vanos and non vanos, maybe the mass air flow sensor.
Old 03-15-2008, 02:16 PM   #15
Dr. Flyview
Formerly Flav_cool
Yes, the MAF is different too, but you should already have that since your car already had vanos. Just get the correct wiring harness.
sold
