Old 06-10-2009, 09:44 AM   #46
///Maluco
5erholic
///Maluco's Avatar
LOL. Thats square man, its Curtis' car is it not?
Actually, it's Roy Wiklund's car with an s14 2.5 AC Schnitzer engine.
Here are the different threads on his build-up. What an awesome machine.
When he spilled the beans on this project
http://www.mye28.com/viewtopic.php?t=6258
In it's raw stage
http://www.mye28.com/viewtopic.php?t=42084
more body prep
http://www.mye28.com/viewtopic.php?t=26599
in paint phase
http://www.mye28.com/viewtopic.php?t=43897
Update
http://www.mye28.com/viewtopic.php?t=44446
Interior
http://www.mye28.com/viewtopic.php?t=42114
assembly
http://www.mye28.com/viewtopic.php?t=45510
more assembly
http://www.mye28.com/viewtopic.php?t=47772
almost complete
http://www.mye28.com/viewtopic.php?t=49348
a few more details to go
http://www.mye28.com/viewtopic.php?t=51075
the end result will speak for itself
http://www.mye28.com/viewtopic.php?t=53202
..........................There will always be followers!
Bimmer Mag......................October 2010.....................Issue No. 93
///Maluco is online now   Reply With Quote
Old 06-10-2009, 11:24 AM   #47
Doh! Thats right, my mistake. I remember showing that car to everyone here one day at the shop because I was in awe of all the stuff that was retrofitted onto the car, like the steering rack swap, e30 rear suspension, work of art exhaust system, etc etc... Really well put together car.
Rippin' Proper | E30 | E36 | E36 M3 | E36 Ti | E30 M52 | 2002 |
craz azn is online now   Reply With Quote
Old 06-10-2009, 12:14 PM   #48
///Maluco
5erholic
///Maluco's Avatar
c'mon dude...more pics of your progress are mandatory now...where they at boy!
Old 06-22-2009, 12:12 PM   #49
5thseries
biggerthen3
ugh i want to restore one soo bad!
5thseries is offline   Reply With Quote
Old 06-22-2009, 12:35 PM   #50
16x9 w/225s get on it.
Dare I squeeze
Old 06-23-2009, 06:59 PM   #51
Got the new diffy installed today... got it from a 320 w/LSD, swapped the rear covers and lifted it in to see how everything mounts up with all the solid bushings. Went right in, looks minty.
Will take it out later down the road after the car is running and I know everything is copacetic and put a hose on the breather on the cover so it won't spit anything out.
Old 06-23-2009, 07:00 PM   #52
325isStephen
ballin'
Old 06-24-2009, 08:37 AM   #53
///Maluco
5erholic
///Maluco's Avatar
cool man!
did you weld on those extra fins? ....I like.
That should slice up some roadkill really well...hmmmmm
Old 06-24-2009, 11:08 PM   #54
D..
where did u get the diff from? u know of anymore that are available?
D.. is offline   Reply With Quote
Old 09-11-2009, 11:07 AM   #55
Got a few updates since.
Worked on the donor 2.0L over the summer. Pretty much threw all the 318 FI parts onto the 02 block, while throwing in some new gaskets and such. Blocked off the fuel pump port. Painted the valve cover and put some newly plated bolts on here and there.
Old 09-11-2009, 11:10 AM   #56
Worked on the front frame rails which were a bit of an issue previously. So far they are only half finished, but we got the base pieces welded in. Still have to make the bottom of the rad support and clean it up so everything looks finished.
Old 09-11-2009, 11:17 AM   #57
Did a bit of fitting the bodywork. Ran into a small snag. The replica Turbo front spoiler I got (which is the same one sold on the bmw2002faq.com) has a bit of an issue lining up with the front fender flares. So far I left it, but I will attend to it later, definitely before the car gets painted.
This is how the car sits as of current. Got the spring sizes picked, just need to buy shocks, and the main of the suspension is more less sorted.
And one wheel test fitment teaser. I am satisfied with the offset, although I may have to space it out 5-10mm. Waiting until I get some longer studs, then I will mount the wheels on all four corners.
Last week got the 318 5spd transmission cleaned up, ready to bolt it on the motor to mock up the driveline, so we can make some mounting points for the transmission support bracket. That should happen I hope within the next two weeks, as school now bites back into my schedule.
Old 09-11-2009, 11:25 AM   #58
///Maluco
5erholic
///Maluco's Avatar
oh yeah baby...that is looking über sweet. Keep it up Rudy
Old 09-11-2009, 12:08 PM   #59
jm1602
jm1602's Avatar
Wow
Look at you man with all that progress and everything. Can I be part of your pit crew next summer?
Old 09-28-2009, 08:02 PM   #60
One more piece to the puzzle. 320 halfshafts. Time for a rebuild.
