Old 04-25-2012, 05:29 PM   #16
5ABIVT
Cheap reliable fast.Pick2
Dont use WD 40. It's a water displacement liquid meaning it WILL dry out rubber and painted surfaces.
SImple green 2 parts water 1 simple green and a brush.
After but before i changed all the bolts and armor alled everything but still obvious.
5ABIVT is offline   Reply With Quote
Old 04-25-2012, 05:35 PM   #17
Robb
EX E30 M3 Owner
Robb's Avatar
I agree... WD40 should only be used to break down dried rustproofing or crusty stock on dirt ! Thats why I used it.
For all other engine cleaning, any engine spray or All purpose cleaner diluted with water would work fine.
BTW, 5ABIVT your engine bay was only dusty.. nowhere near as bad as mine was !
Old 04-25-2012, 05:41 PM   #18
5ABIVT
I probably missed that on the rust proofing .. Wd40 will def help get rid of that stuff. I hate degreaser personally because it dries out rubber as well. I like to think of it as a cleaner for engine blocks only from the prehistoric carbureted days where there wasn't so much rubber and plastic underhood. Back then domestic car makers couldn't build a car right let alone valve cover gaskets etc that would leave oil all over the side of the block that would accumulate dirt and debris. Degreaser is good for that.
Old 04-25-2012, 05:45 PM   #19
5ABIVT
Btw nice job on the clean up !!
Old 04-30-2012, 07:50 AM   #20
lotp_e90
Originally Posted by Randy View Post
i dont believe it.
I can personally vouch for robb's EF (91 civic). One of the cleanest ones I've seen at a Torontocivicsclub meet. Robb I didnt know you were on here? I use to be part of tcc as well; 91ef
lotp_e90 is offline   Reply With Quote
Old 04-30-2012, 11:00 AM   #21
Robb
EX E30 M3 Owner
Robb's Avatar
Cool.
Yea I used to have an 89 M3.
Old 05-30-2014, 11:18 PM   #22
Robb
EX E30 M3 Owner
Robb's Avatar
Anyone here tried this method ?
Old 05-31-2014, 12:15 AM   #23
Yes, works good! Just don't try to clean up the WD40 with pressure washer!
Old 06-01-2014, 09:36 PM   #24
partner103
Wow... I must try this.
Personally, that's just me.
I use Coke Cola for surface rust removal on my beater.
Works like a charm.
partner103 is offline   Reply With Quote
Old 10-24-2015, 05:07 PM   #25
BestodaBest
Definitely interesting, but seems extremely labour intensive when compared to using a good engine degreaser and heated power washer...
BestodaBest is offline   Reply With Quote
Old 05-19-2016, 02:37 PM   #26
esum
Whoa!!
esum is offline   Reply With Quote
Old 08-14-2016, 12:32 PM   #27
AWD
Looks sweet, gonna try this sometime! My engine used to look that clean..
AWD is offline   Reply With Quote
Old 08-26-2016, 09:43 PM   #28
Robb
EX E30 M3 Owner
Robb's Avatar
Post pics before after
Old 09-11-2018, 11:49 AM   #29
maxum101
Impressive, have to give it a try
Sent from my SM-N950W using Tapatalk
maxum101 is offline   Reply With Quote
