Old 11-17-2013, 08:27 PM   #76
Originally Posted by E36 Power View Post
So is this the best way of going INTO the test?
Also - my car is swapped from manual to automatic so the check engine light bulb will be on regardless. The bulb has been pulled. Also, one of my o2 sensors is donezo - need that fixed before the test? what a pain this is.
An auto to manual swap shouldn't cause a check engine light if done right. What codes are you getting? Of course the o2 sensor needs to be replaced before the test. That is probably the most important emissions related sensor which can cause your car to run rich and burn more gas.
Also pulling the bulb will be an automatic fail. They take pictures of the dash, key on engine off to ensure the check engine light, lights up. Not only that but they'll also know you have codes when plugged into obd2 port. Any engine code is an automatic fail.
Old 11-17-2013, 08:42 PM   #77
E36 Power
DEFINE GF
What a headache!
I guess I need to get this looked after asap. What a headache wow.
96' 328i M Tech | 15' 328i M Sport
E36 Power is offline   Reply With Quote
Old 11-17-2013, 08:59 PM   #78
What a headache!
It's not really a headache if you keep up with maintenance and have a properly running car.
It's actually a much easier test to pass as long as the computer thinks everything is good, it doesn't matter what comes out your tail pipe
Old 11-17-2013, 10:36 PM   #79
E36 Power
DEFINE GF
I have my peake scan tool so I'm going to run it tomorrow and see what codes are coming up. I know for sure that 2/4 o2 sensors are throwing a code though
Old 11-18-2013, 11:53 AM   #80
jrsmitchell
Switchtronic
jrsmitchell's Avatar
Are we talking about your '96 328? Model year 1997 and older get's the old two-speed idle test. They shouldn't need to check the status of your CEL.
Jeff | '94 BMW Alpina B3 | '06 BMW 325XI Wagon
jrsmitchell is offline   Reply With Quote
Old 11-18-2013, 12:15 PM   #81
E36 Power
DEFINE GF
Ya my car is a 1996 328i.
So I'm exempt from this check engine light bit??
Will one of 2 o2 sensors being shot fail me?
Old 11-18-2013, 12:18 PM   #82
My bad, forgot about the older cars. My experience so far was with a 2000 528i which fail because of the check engine light. Passed once the issues were resolved and all monitors were ready.
Old 11-18-2013, 02:16 PM   #83
jrsmitchell
Switchtronic
As I understand it, they shouldn't care if your check engine light is on for a 1997 and older. They should do a quick visual inspection ("Yep, looks like a car!") and then they'll do the 2 stage idle test where they put a sniffer device to measure the CO and HC in the exhaust at low and medium revs.
If your shot O2 sensor causes abnormally high emissions of CO and HC then you are going to fail. If not, you won't. You probably won't know unless you try
Old 11-18-2013, 02:22 PM   #84
TSI
Reverse Gear Member
Nah, they won't do the test at all if you have a CEL. In my experience, however, a 3 min disconnect of the battery immediatly before the test should address that issue
TSI is offline   Reply With Quote
Old 11-18-2013, 03:45 PM   #85
E36 Power
DEFINE GF
LOL seems to be some different opinions if they care or not about the check engine light
I guess I will just go and see what happens - bulb pulled and on (I know this because of the peake tool)
Old 11-18-2013, 04:41 PM   #86
jrsmitchell
Switchtronic
Print out this:
http://www.ene.gov.on.ca/environment...STDPROD_075681
Or this:
http://www.ene.gov.on.ca/stdprodcons...rod_080001.pdf
and ask them to point to where they should check the status of the light for a '97 and older.
Granted I have a '94, but they didn't look at the dash or attempt to hook up to my OBD1 port. Shouldn't be any different on a '96.
Old 11-19-2013, 02:47 PM   #87
E36 Power
DEFINE GF
Print out this:
Or this:
thanks for that - i was actually skimming over that between posts and saw the pre 97 bit
Where did you get your test done? Hoping for now CEL scan off the bat. Usually just gone to crappy tire at queensway / 427
Old 11-19-2013, 03:18 PM   #88
jrsmitchell
Switchtronic
Call ahead, alot of places got rid of their sniffer equipment and don't do the two stage idle test anymore I used to get mine done at the local CT as well but they only do the OBD2 test now.
There's a tool you can use on the Drive Clean site to find one that does it. I got mine done at Active Green & Ross near Eglinton and Dixie. There were pretty cool once I reassured them it was normal for an Alpina to have two VIN numbers
Old 11-19-2013, 03:45 PM   #89
E36 Power
DEFINE GF
HAHA ya I can imagine! picturing the techy scratching his head
Going to try there, not to far a drive for me anyways. Thanks! Keep this thread alive with what happens with mine
