Old 12-28-2017, 05:34 PM   #1
Gtfour
Gtfour's Avatar
FS: 2005 BMW E46 M3 ZCP track car
Vehicle Specifications
BMW E46 M3 ZCP
Build Date: XX/2005
Competition package
6 speed manual transmission
Carbon Black
138100 km
No accident, Clean title
Currently plate in Qc province
PRICE: 18000$
Modification list
Drivetrain
TTFS Alpha-N Tune, same tune when I had the CSL CF intake manifold on the car.
OEM airbox with Pipercross drop in filter (washable)
Custom slotted beauty cover
Custom catless headers with ceramic coating
OEM custom rasp delete section 1 (2 resonators)
AKG Motorsport 75D engine mounts
AKG Motorsport 75D transmission mounts
AKG Motorsport 75D differential mounts
OEM overflow tank custom relocation kit
RE coolant overflow line
UUC braided SS clutch line
Wrinkle black painted oil filter cap
SAP/EGR delete with custom block off plate
Charcoal canister removed
Mechanical fan & shroud removed
Clutch delay valve removed
Exterior
Lang Racing carbon fiber roof (NOT a CHEAP CF vinyl wrap...OEM roof was removed)
HARD Motorsport sliding front tow hook
OEM amber sides and corners reflectors signal
Lamin-X amber taillights film
Color match painted front reflectors
Gutted OEM trunk
Allstar duct in front bumper for intake
Custom block off plate front bumper passanger side fog light hole
Ziza 6000k halogens headlights bulbs
Xenon to halogens headlights conversion
Headlight auto-levelling switches removed
Headlights washer nozzles delete
Windshield washer reservoir removed
Fog lights removed
Suspension
TcKline DA (Double adjustable compression & rebound) dampers
Hyperco/Eibach springs 700 front / 800 rear
TcKline camber/caster plate
Ground Control rear suspension mounts
AKG Motorsport Rear Trailing Arm spherical bearings
AKG Motorsport 75D Front Control Arm Bushings
AKG Motorsport 75D rear subframe mounts
Turner Motorsport rear subframe reinforcement
Rogue Engineering Rear Control Arm spherical bearings
Brakes
OEM front calipers with non ZCP carriers
OEM front rotors 325x28mm
Performance Friction front race pads compound 11
Guide pins Brass bushings
Goodridge Stainless Steel braided front lines
DBA 4000 slotted rear rotors **BRAND NEW**
Performance Friction rear race pads compound 11 **BRAND NEW**
ECS Tuning Stainless steel braided rear lines
Backing plates removed
Handbrake delete
Interior
Custom 8 points roll bar tied-in to rear subframe, made in DOM 1.75"x0.095", all plates are 1/8" thick and 20sq.in minimum, every tubes are weld 360, will meet most organizations regulations and will be legal if you turn it into a full cage for a road racing.
Rear bulkhead was removed, it makes more space with the roll bar so you can bring another set of track wheels and put them where the rear seat was originally.
Racetech 4000w race seat
Racetech aluminum side mounts
Custom floor mounts
Custom aluminum glove box delete panel
Custom aluminum radio/HVAC delete panel
MotoMaster carpet instead of OEM to save weight
OEM alcantara steering wheel
Grip tape pedals
Split loom on every wires inside the cabin
AKG brass clutch pedal sleeves
AKG delrin brake pedal sleeves
IND style tall delrin shift knob
Braille 17Lbs lightweight AGM battery
Rogue Engineering clutch stop
Tinted windows 35% front 20% rear
Wink 5 panels mirror
AC delete (compressor, condenser, lines, air dryer)
Heater core delete with custom block off aluminum panel
Leather interior removed
Headliner/sunvisors removed
Audio with wiring harness removed
Airbags and module delete
Wheels
TR MT1 anthracite wheels
18x8.5 et44 18x10 et25
90mm studs kit
18mm spacers for front wheels
Nitto NT01 245/40/18 & 275/35/18
Fluids
GULF RBF1000 brake fluid
Redline D4 ATF transmission fluid
LiquiMoly 10w60 engine oil
Gulf 75w140 diff fluid
New OEM parts/Maintenance done
VANOS line
VANOS filter
Water pump
Fuel pump
Fuel pressure regulator
Fuel filter
Bosch alternator
Valve cover gasket with spark plugs seals
Throttle body boots with reusable clamps
Transmission selector rod seal
Guibo flex disc
Driveshaft center bearing
Oil level sensor gasket
Oil pump pick up gasket
Constant pressure valve o-ring
Crankshaft position sensor
Coolant overflow reservoir
New Windshield while doing the carbon fiber roof
Weight should be close to 2800lbs and should do around 300whp
Can consider trade + CASH $$$$$ ON MY SIDE for manual gearbox/non VGA E30 M3, 2001-2002 Z3M Coupe, E46 M3, Z4M Coupe, E90 M3 (no E92 M3), F80 M3 (no F82 M4), Porsche Cayman S, 997.1 Porsche Carrera S (no convertible), Lotus Elise/Exige
Send me a pm with your email for pictures, my Photobucket account is down...
https://www.kijiji.ca/v-view-details...equestSource=b
Gtfour is offline   Reply With Quote
Old 02-13-2018, 06:03 AM   #2
Gtfour
Gtfour's Avatar
sold/
