Go Back   maXbimmer Forums > maXimum Tech > X series
Old 08-21-2017, 09:15 PM   #1
rockyfranky
bmw trunk opens by itself
I brought fully loaded BMW X3 in April, last couple of weeks I noticed three times trunk opening by itself in garage, since garage closed it also done damage to the truck (small dent), I thought may be key got pressed as I used keep in my laptop bag, after first incident kept the key in bed-room closet in a plastic box when I am not using X3, after that I noticed two times open trunk, after the first incident I attached the theromcol piece to garage door so there is no more damage, but I am concerned it is safety issue if this happens in parking lot or while driving, I goggled and many other also complained. Is anyone else faced the similar problem is something known issue, is BMW addressing. Any inputs will be appreciated.
rockyfranky is offline   Reply With Quote
Old 08-22-2017, 11:22 AM   #2
xander_g
Do you have the sensor that opens the trunk when you move your foot under the bumper?
xander_g is offline   Reply With Quote
Old 08-22-2017, 08:19 PM   #3
rockyfranky
Yes I do have sensor that opens trunk door waving the legs, but that works only if key in pocket/hand and couple of feet distance.
Old 08-23-2017, 08:46 AM   #4
Mikey83
Mikey83's Avatar
Can you get the car scanned for errors? something is triggering it to open either as a safely or false signal. Worth a shot
Current - 2011 E70 X5 3.5i
Sold
2003 745Li Titanium Sliver Metallic w/ Black Interior
21" OEM Style 128, Angel iBright V3 w/ Matching Fogs, H&R Springs, BTUM8000, LED Side/Front Markers, White Bulb Interior/License Plate,
Stealth Bulb Signals, 15mm Rear Spacers, ACS Style Roof and Trunk Spoilers, Debadged
Mikey83 is offline   Reply With Quote
Old 09-11-2017, 01:46 PM   #5
MANDD
Autobahn East
Assuming that you have the F25 X3, there is a software update for the lock unlock logic to correct this occurrence.
Mark.
