Old 03-29-2008, 06:42 PM   #1
kerrynzl
E36 320 OBD1 Harness
Does anybody here know if I can swap a Siemens ms40.1 DME to a Bosch red label 413 DME using the Siemens harness from my 320 coupe [non-EWS]
I want to install a M52b28 engine I have lying around [ unfortunately it's OBDii and EWSii ]
Or could the Siemens ms40.1 be remapped to the larger engine?
My car is a RHD coupe ,the DME is on the LH side firewall so I can't use a BOSCH 413 harness [ from a USA care ]
I'm told all vanos [Non Nth American e36's use a Siemens DME ]
Any knowledgable answers would be appreciated
Kerry
kerrynzl is offline   Reply With Quote
Old 03-30-2008, 02:31 AM   #2
From what i know, you can use your old 320 harness/DME/EWS/intake/sensors to an M52 without any problems...
Old 03-30-2008, 03:08 AM   #3
kerrynzl
Hey Thanks for that
My Car is Non-EWS ,and I would prefer to keep it that way.
Because the 2.8 uses basically a 2.0 intake, I was just going to swap everthing over and use the larger 2.8 throttle body and Airflow Meter.
Can the Siemens unit measure the correct amount of Air [ slower airspeed because of larger diameter MAF ]
All I'm after is a lot more torque & approx 25% more power [ standard 2.8 behavoir ] So if my little coupe drives as good as a stock 328 I'd be happy [ I have a race-car for venting frustations ,not the street ]
incidentally here in NZ we have no "smog laws" and 98 octane pump gas [ our modification laws are fairly liberal as well ]
All the best ...Kerry
