Old 11-07-2017, 10:54 PM   #16
Бумер
Time for an update.
The crossbeam was rotted beyond repair. I had to fabricate up a new one since I don't believe BMW makes this piece (at least I couldn't find it). The corner sections were still ok so I cleaned them up and rewelded.
While poking around discovered driver side wheel well had some rust on the bottom. Ended up cutting out and redoing the whole corner.
Бумер is online now   Reply With Quote
Old 12-02-2017, 08:01 PM   #17
Бумер
The good news is rear undercarriage is just about done.
Now the bad news. Started poking the floor in the driver's area and poked a rather large hole. After yanking the carpet and doing some more poking discovered a rather large hole. Looks like it rusted out from the inside so water must've been getting into the driver floor area.
Old 12-03-2017, 12:56 AM   #18
TSI
Reverse Gear Member
Eek. Although not terminal, I'd be a little concerned about the condition of the frame rail!
TSI is offline   Reply With Quote
Old 12-03-2017, 01:14 AM   #19
Бумер
It looks worse in the pic than it actually is. Frame rail is solid. Still had factory paint on the inside after I vacuumed out all the crap. I'll post a better pic tomorrow of what it looks like cleaned up. Granted it will need a rather large patch panel.
Old 12-04-2017, 12:05 AM   #20
Бумер
Here is what it looks like cleaned up.
Old 12-05-2017, 09:39 PM   #21
Бумер
Fabbed up a patch panel and welded it in. Still gotta clean up the welds and seal it.
Old 12-08-2017, 01:55 AM   #22
Call me crazy but how the F#$K does a frame rail get painted INSIDE!!!??? Maybe that's how it lasted 30 years! lol
Most models E30 E36 E46 E90 E92 E93 E28 E24 E34 E39 E60 E61 E32 E38 E65 E66 X3 X5 M3 M5 Z3 Z4 F30 F32 F10 F01
Old 12-08-2017, 08:54 PM   #23
Бумер
I am guessing it was primed then welded in place. Then when the whole car was painted some paint overspray made its way through the holes in the floor pan that lead to the rail.
Old 12-10-2017, 03:06 PM   #24
Ceeker
nice work...like the fact you took the time to put the design back on the metal to match the rest of the floor. after grinding the welds down you won't even tell..
You can weld my car anytime. ;-)
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 12-11-2017, 09:34 AM   #25
Should have left out those holes where the plugs go. They aren't functional, they were only meant for helping the chassis drain after it went through an acid dip on the assembly line to clean and etch the metal before paint.
Nice work though!
Old 12-11-2017, 10:18 AM   #26
Бумер
That's good to know. I wanted it to look as close to factory as possible. Plus I can use them to spray rust proofing into the frame rails.
Old 12-29-2017, 06:35 PM   #27
Бумер
If anyone is cutting up a late model E30, I am looking for a rust free tail panel with a single tail pipe cut out. Found one on Ebay in Europe but it's close to 400 bucks.
Old 12-31-2017, 12:23 PM   #28
Ceeker
you can get it cheaper from bmw I believe. most e30's have rotted license plate light area and maybe even tail lamp or quarter panel rot. Better off buying one new. the odds of finding a clean unrusted piece is slim to none.
Old 12-31-2017, 03:32 PM   #29
Бумер
I priced out a piece from Euro 318 and it was over $500 which is nuts. The US price is cheaper but the piece is for a 325 with dual exhaust tip cut out. I am trying to keep this as close to original as I can.
Old 01-02-2018, 07:45 PM   #30
Ceeker
I actually preferred the duel cut out when I had my 318is. I had rot on the rear panel and quarters so when I ordered mine I got it with the bigger hole.
the panel with the single cut out should be available.
Look at things this way...with the money you saved in the other areas you could consider allocating to such items which are costly or hard to source?
however here is the bmw part number for the single exhaust tip panel:
41348121771 - this will only fit (designated for) 318i and 318is
41348103088 - twin exhaust tip panel
