Old 10-03-2014, 07:26 PM   #1
Jokers-Wilde
Freezing Rain
It's possible that I may have to use my Z4 during bad weather this winter and I'm concerned that freezing rain may seal the windows to the top rubber. As the window drops as you open the door, I don't want it ripping the rubber seal. So I was wondering, if it calls for freezing rain, whether I should run some Vaseline along the seal to prevent moister ingress. No moisture = no ice. Any comments please.
Jokers-Wilde is offline   Reply With Quote
Old 10-03-2014, 11:48 PM   #2
blk3
blk3's Avatar
Couldn't hurt
Old 10-04-2014, 06:28 PM   #3
Use Gummi Pflege or Wurth Rubber Maintenance. Wouldn't recommend vaseline.
Old 10-06-2014, 09:04 AM   #4
Steve-O
When I had my Eagle Talon with the frameless windows I used silicon lubricant on all the rubber seals around the windows, doors, trunk and hood. It never froze, even through a few pretty big ice storms. You can get it anywhere: http://www.canadiantire.ca/en/automo...ubricants.html
I still use it on every vehicle I use in the winter. I have never had a problem.
Steve-O is offline   Reply With Quote
Old 10-06-2014, 12:51 PM   #5
sb_600
sb_600's Avatar
the bigger problem with freezing rain is that the ice builds up at the bottom of the window where it meets the door. That's what prevents it from dropping. If you can chip that away before you open the door, it will definitely help.
Shawn
Old 10-06-2014, 04:16 PM   #6
Dinanstu
...an old credit/points card is perfect for sliding between rubber seal to break the ice.
Old 12-21-2014, 02:29 PM   #7
BmW1819
Silicone spray won't have any problems
Old 05-15-2015, 05:59 PM   #8
i drove my roadie in the freezing cold/snow a couple times. no problems.
