Old 09-11-2015, 08:55 PM   #1
joeh
soft top motor
Hi all i am new to the bmw world and am very excited. It is nice to find a canadian site , may actually get to meet some people you speak with. But as i was going to ask does anyone know anything about the soft top motor? I can hear the motor run or at least think I can but the top does not move. Is there a way to check or replace the motor? Any advice is appreciated.
joeh is offline   Reply With Quote
Old 09-11-2015, 09:36 PM   #2
The roof uses a hydraulic pump, not a motor...to get at it you must remove the top, so not an easy fix/check. Are the locks opening properly?
Most models E30 E36 E46 E90 E92 E93 E28 E24 E34 E39 E60 E61 E32 E38 E65 E66 X3 X5 M3 M5 Z3 Z4 F30 F32 F10 F01
Old 09-13-2015, 10:28 AM   #3
accent
Hi joeh
There are a few things that you can check; did the roof retract before, is the bypass valve in the correct position, to name two
There is lots of documentation on replacing the hydraulic motor, try google.
Most of the documentation is on other sites I'm afraid but there is detailed instructions on checking out what is the cause
accent
accent is offline   Reply With Quote
Old 09-14-2015, 12:50 PM   #4
in your trunk, on the left hand side, pull out the carpet. turn the knob thingy completely the other way. someone may have bypassed the pump for manual operation (although this likely means there's a problem with it)
Old 05-13-2016, 09:45 PM   #5
SilverBlitz
SilverBlitz's Avatar
I have a like-new pump and hydraulic lines if you need to replace yours.
SilverBlitz is offline   Reply With Quote
