Old 12-01-2010, 04:03 PM   #1
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
Question Driveline vibration....only in second gear
Driveline vibration happening under anything but light load ONLY in second gear from 1500-2800rpm or so.
I think my flex disc is ok. Don't know about the driveshaft center bearing, but if it were one of these, wouldn't it happen in all gears?
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 12-01-2010, 04:57 PM   #2
rider-.
center bearing. just experienced this a month ago. same symptoms.. it will start doing it in other gears as they get worse
Old 12-01-2010, 06:14 PM   #3
Driveline related, flex disc, csb, loose or unbalanced driveshalf can all cause it,get someone to look at it
Old 12-01-2010, 07:44 PM   #4
Dr. Flyview
"Mint"
^^ lol thanks for telling me what I stated to begin with.
Thanks rider, I guess that's most likely what it is.
sold
Old 12-02-2010, 11:11 PM   #5
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
If you know everything, don't ask for advice.
Drivelines are really sensitive, and 1800-2300 rpms is what speed range? If you're going that speed in first you have a lot more load therefore less play in driveline and less vibration. CSB is the second thing to check after flex disc, so go check it.
