Old 11-11-2010, 09:52 PM   #16
Daonhathai
Daonhathai's Avatar
Originally Posted by E36is View Post
idle shutdown, im suspecting its the idle control valve, or throttle position sensor. clean the connections first and see if that corrects it, if not, get a new or used one.
the cd is usually located in the trunk, its a black box that houses a 6 cd cartridge. keep it stock.
I've cleaned the connectors and all others around the TB just to be sure I'm getting the two. The car doesn't do it as often, but once a while will still either shut down or hesitate on acceleration. I'm guessing I'd have to replace one or the other at this point (or both...).
Daonhathai is offline   Reply With Quote
Old 11-11-2010, 10:09 PM   #17
richie_s999
Did u say Mazda fuel filter on a BMW ???
Old 11-11-2010, 10:25 PM   #18
Daonhathai
Daonhathai's Avatar
Well, it's not Mazda Specific. I inteded to use it on one of my RX-7's. I believe it was a Bosch or Denso, it was a universal since (at the time) mazda RX-7 OEM one was like $50+ and I got this for $30, I trust either name whichever one it is. If BMW has make and/or model SPECIFIC fuel filters then I'll go an order one, otherwise, I don't see the harm here from using universal filters.
Old 11-11-2010, 11:05 PM   #19
JvzwetE36325
JvzwetE36325's Avatar
What is it that you're trying to reset? Just your Oil service light? I found a great diy, can be done in 3 minutes
http://www.bmwe36blog.com/2007/02/24...service-light/
1995 325i - Sold
1997 540i/6 - Wrecked
1998 328is M/pkg, Born and raised in Germany - Sold to a Max member
2000 540i/6 - Sold
JvzwetE36325 is offline   Reply With Quote
Old 11-11-2010, 11:17 PM   #20
Daonhathai
Daonhathai's Avatar
Thanks a bunch!
The more I drive the car, the more I love it. Now I want to keep it from my dad ahaha! Too bad it's auto =(
Old 12-04-2010, 04:12 AM   #21
Daonhathai
Daonhathai's Avatar
Just wondering if a 94 318is icv is interchangeable with a 98 328is?
Also, experiencing the rear passenger side of the carpet flooding with water, any ideas?
Old 12-04-2010, 06:55 AM   #22
richie_s999
Look up the parts on www.realoem.com
if the part numbers are the same then they are the same part
