Old 12-17-2017, 01:59 PM   #1
Fergy
Alternator wiring question
Hi everyone! New here so sorry if this has been covered before but I couldn't find anything on it. I have a '99 323i as a winter car. We suspect that the front bearing in the alternator is failing. While pulling some parts off a scrapped 325i, we grabbed the alternator. Physically, the two alternators look identical and both are 120 amp but mine has a 2-wire plug whereas the one from the 325i has a single wire plug. Does anyone know what the differences are and if I can somehow use the single-wire alternator on my car?
Fergy is offline   Reply With Quote
Old 12-17-2017, 08:14 PM   #2
jabela
Realoem should help you out. I recall some cars have a higher capacity alternator.
You can also check on http://forum.e46fanatics.com/
http://www.realoem.com/bmw/select.do?vin=JW52228
www.maisonapothecare.ca
