Old 11-22-2011, 06:52 PM   #16
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
^^ Take it to RMP man, check wth is going on. That's weird that the headgasket leaks to the outside.
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 11-22-2011, 07:44 PM   #17
kenmar
Originally Posted by noodles101 View Post
im loosing about a cup of coolant every 3 weeks.
its leaking very slowly and only sometimes from the passenger side engine area where o2 sensor and exhaust manifold is.
The cooling system block drain plug is in that area. If you have no other symptoms, maybe it just worked its way loose?
kenmar is offline   Reply With Quote
Old 11-22-2011, 08:35 PM   #18
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
+1. Or it could be a badly corroded freeze plug. Do you have the right mix of coolant to water in there? Are you adding straight water?
Old 11-23-2011, 11:07 AM   #19
5style
Lala-land
5style's Avatar
the above, it doesn t sound like a headgasket
