Old 06-22-2019, 08:47 PM   #1
South
No start, no fuel pressure
electrical and wiring diagrams....absolutely hate them
So i was driving in the rain and suddenly car died right after a pot hole. literally 30 meters from home. crank but no start. no codes.
its a 97 540i6...first thing i did was add gas because i was near empty.
glovebox and trunk fuses. all good.
then I unplugged fuel lines and viola no fuel.
so I gambled on a fuel pump replacement because i figured my driving habits of refueling when it gets to the line properly fried the pump.
nope. still have problem. fuel pump is not turning on.
I do have spark.
this is the point where you say....its your fuel relay...
well the one in the glovebox i can hear ticking on when i put in fuse 31. so its good?
the one in the rear I have no idea because there are 4 relays. 1 dark green. 3 identical light green ones. youd think k96 would be labelled somewhere on them, but nope.
so anyone have a clue which relay out of the 3 it is and which terminals on it to jump?
also. if i replace the glovebox and rear relays...and it still doesnt start...what then? crank position sensor i heard may be the culprit...
95 325i - m52 swap, M50 manifold, chiped, dinan cai, welded diff - 2012-2016
96 328is with 375km, Madeira violet, Magma Vadar interior, LSD, Hartge body- 2014 winter
99 318ti matt black, M3 body, m50 stroker- parted
97 540i6 ACS - 2016-present
South is offline   Reply With Quote
Old 06-29-2019, 01:52 PM   #2
South
After replacing all the fuel relays and directing hooking up a battery to the fuel pump to make sure it works. turns out to be a bad ground wire.
