Old 05-18-2016, 12:23 AM   #16
^^^I think you need a Cadillac! Or air ride. I have coilovers on 3 of my cars, and none of them make ANY noise!
Most models E30 E36 E46 E90 E92 E93 E28 E24 E34 E39 E60 E61 E32 E38 E65 E66 X3 X5 M3 M5 Z3 Z4 F30 F32 F10 F01
Old 05-18-2016, 01:41 AM   #17
JayWells
So I guess I should be looking at lowering springs then?
JayWells is offline   Reply With Quote
Old 05-18-2016, 07:41 AM   #18
windwagen
windwagen's Avatar
I would say yes - considering what your goal is.
As for proper coilovers and ride...this is very subjective
Maybe ask take a ride in a similar car? You're welcome to try mine... both are 5 series though... I have a wagon with stock sport suspension and the M5 has coilovers.
E39 M5 - for Sunny Days
Old 05-18-2016, 01:11 PM   #19
ac_2007
Cruising in Top Gear
ac_2007's Avatar
With many coilover setups for the E46, rear spring design isn't the best.
This causes the coils to bind and make noise, particularly at parking lot speeds.
I'm sure you guys have come across more than a few E46s with rusted rear springs (aftermarket), due to this binding.
Happened on my M3 and 325, with 2 different coilover manufacturers.
http://www.m3forum.net/m3forum/showthread.php?t=375086
Old 05-18-2016, 01:29 PM   #20
CrowsFeast
Intermediate Tracker
If you just want it for looks while maintaining ride quality, then you can do springs or coilovers. Either one is a valid option. With springs i think you may find that the gap will be uneven which may or may not drive you crazy. With coilovers you can adjust them however you like, including raising it up for the winter.
Either way what you need to look carefully for is the spring rate. You want a spring that is fairly close to the stock rate (they will all be at least a bit higher) and you'll want to upgrade your struts to match the stiffer spring rates, as well as because the stock struts likely won't last as well at the lower ride height.
If you go for coilovers then I highly suggest something with a stainless steel body so they won't be seized on you before or after the winter. There's differing opinions on whether or not to coat the threads in anti-seize. On the one hand it should keep it from seizing (obvious) but on the other it may collect dust and grit causing extra wear on those threads, or jamming them up.
CrowsFeast is offline   Reply With Quote
Old 05-18-2016, 01:48 PM   #21
jabela
If the coil is binding at rest doesn't that mean that the initial spring rate of the progressive coil is too low?
www.maisonapothecare.ca
Old 05-18-2016, 05:22 PM   #22
JayWells
Very very informative. Thank you very much for this. I'll do some looking around and maybe visit stance factory in Ajax to get a more in-depth look at pricing and etc. Thank you all for your comments and replies, I truly appreciate the help from everyone.
Old 05-18-2016, 09:11 PM   #23
newbe46
That's spot on. The clunking noise when going over small humps drove me nuts more than the firmer ride.
And indeed, I'm already looking into an SUV for my next ride.
newbe46 is offline   Reply With Quote
Old 05-18-2016, 10:03 PM   #24
earthling
You didn't mentioned your budget, but based on your "wish list" I would recommend KW variant2.
1- You can change your ride height in a wide range.
2- You can adjust the rebound from stiff to soft in 16 steps to your liking.
3- They are stainless steel, so you don't have to worry about corrosion.
Keep in mind though, if you planning to change the ride height back and forth, then most likely you need to do an alignment every time you make a change.
Also, if you go with coilovers, I would recommend reinforcement plates for your strut towers and rear shock mounts.
earthling is offline   Reply With Quote
Old 05-19-2016, 12:31 AM   #25
jabela
Odd, my ISC N1 coilovers have similar progressive rear coils but no noises at all. Perhaps because the spring rate is stiffer? I don't recall seeing them in bind.
