Old 04-11-2014, 01:02 AM   #1
Slowered318
Washer Pump Power
Can someone with a multimeter do me a huge favor?
I'm getting 12 volts on both the purple/black and brown/black wires at the washer pump, it doesn't seem right but it could be normal? In the middle or replacing all the headlight wires from the fuse box forward, I want to know if I have shorted something out in the process.
Old 04-11-2014, 08:10 AM   #2
cirrusblau
Is the VI/BK always hot and the ground switched? Does the pump work when you pull the lever to squirt?
Old 04-11-2014, 08:33 AM   #3
Slowered318
Both wires are hot actually (+12.7 volts). Looks like the pump runs on a switched ground. I haven't tried out the pump yet, still working on the wire loom that wraps around the front of the car. Pump worked fine prior and to my knowledge I haven't changed anything.
Old 04-11-2014, 10:46 AM   #4
cirrusblau
If it's a switch ground, then BK/BR from the motor to the switch would be same voltage as VI/BK. If you disconnect the washer pump, BK/BR should not have continuity to ground until you pull the lever to activate the pump.
Without having the schematics in front of me, that's the best I can explain, based on what you've said about the switching on the ground.
Old 04-11-2014, 11:17 AM   #5
Slowered318
As stated, I'm getting power on both terminals with the pump disconnected, how much power I don't know. It just doesn't seem right, that's why I need someone to check on a working car in case I'm not understanding what's going on inside the K10 wiper/washer control unit.
Here is the full circuit.
File Type: png Screen Shot 2014-04-11 at 11.08 AM.png (235.0 KB, 25 views)
Old 04-11-2014, 02:12 PM   #6
cirrusblau
When you pull the washer lever on the steering column, you ground the connection, making the motor run. You also ground pin 85 (I think that says 85??) which tells the K10 wiper unit to cycle the wipers.
edit: actually, not sure if the K10 would provide low amperage at 12 V?
Old 04-11-2014, 02:30 PM   #7
Slowered318
This is exactly what I would like to know.
Old 11-03-2017, 02:41 PM   #8
Roadent
E30 windshield washer pump
Hoping this helps others with the washer pump conundrum! After purchasing a new pump, t-junction, scouring the web, testing circuits, checking fuses, ground - many hours. I offer the start point for anyone with this issue.
If your windshield washer pump is not working, but your wipers are, then the issue is likely with the contact in the wiper/washer switch on your steering column. I recommend you start with sanding the contacts (see arrow in photo) for the washer switch on the control arm, which will likely remedy your pump issue. If that does not work, then test your pump separately - hot wire to battery. After that then go to other forums for testing fuses, control modules, etc.
Roadent is offline   Reply With Quote
