Go Back   maXbimmer Forums > Classifieds > For Sale > Drivetrain, Engines & Transmissions
Old 11-05-2018, 12:10 AM   #1
edvc520
E30 complete transmission swap kit + extras
Selling a complete transmission swap kit + extras
1) Complete Swap kit:
- Getrag 260 5 speed
- Drive shaft
- Flywheel
- Pedals
Unknown on mileage, test drove the car before it was parted and there was no issue. Purchased from member craz azn.
Selling the kit now as I sold the car.
Brand new Extras:
Transmission rebuild kit consist of:
- Drive Shaft Flex Joint
- Seal - Input Shaft
- Seal - Manual Trans Selector Rod
- Flywheel Bolt
- Fluid Hose - Clutch Slave Cylinder,
- Spring for Throw-out Bearing Release Lever
- Pivot Pin for Throw-out Bearing Release Lever
- Exhaust Manifold Gasket to Header
- Pilot Bearing
- Rear Main Seal/Flywheel Seal
- Bolt - Clutch Pressure Plate to Flywheel
Shifter rebuild kit:
- 187mm DSSR selector rod
- Lever Insulating Rubber Boot
- E30 manual shifter boot
- Z3 1.9 shifter
- e30 delrin shifter bushing kit
- BMW 80A polyurethane transmission bushings
Clutch kit consist of:
- Sachs clutch
- Sachs clutch slave cylinder
Swap kit alone is $600
$900 with everything extra
Located in Markham
edvc520 is offline   Reply With Quote
