Go Back   maXbimmer Forums > maXimum Tech > 1/2/4 series
Old 02-25-2017, 04:06 PM   #1
Mat135i
135i cold start idle issue
After leaving the car parked outside overnight it always shakes and runs rough when i start it. When i start driving and the car warms up it idles much better even tho it still doesnt idle perfectly smooth. What could the problem ? Did the walnust blasting and new plugs installed couple weeks ago.
Mat135i is offline   Reply With Quote
Old 02-25-2017, 08:07 PM   #2
Trekz
Programming
Sent from my Nexus 5 using Tapatalk
Trekz is offline   Reply With Quote
Old 02-26-2017, 02:51 PM   #3
HavocSteve
Not necessarily the programming. Mine makes the vanos tick until the a good 10 minutes its warmed up a bit. Might need new plugs/coils. I replaced my plugs and it helped a little bit but I should have done coils as well.
Did you get the PPK or even get the MHD programming off of google play? Might also want to look at the 1addicts forum as well. MaxBimmer is mostly geared towards to older gen BMWs. You can get any info or DIY off n54addicts/1addicts web forum. (Sorry for posting those names, remove if needed admins).
Old 02-26-2017, 04:38 PM   #4
Rough cold start after sitting overnight and not after just a few hours or minutes = leaky injectors.
Old 02-26-2017, 08:11 PM   #5
Mat135i
Yes, it looks like i will be needing new injectors.
Old 02-26-2017, 08:47 PM   #6
Check with BMW, there is a long standing recall on the N54 injectors.
Old 02-26-2017, 10:47 PM   #7
Mat135i
Thanks, looked online and found out my cars build date is eligible for the recall. Funny considering the dealer did not mention the recall to me when scanning my key.
Old 02-26-2017, 11:47 PM   #8
Mat135i
I can't seem to figure out if the recall includes Canada tho.
Old 02-27-2017, 08:12 AM   #9
Blackedout95
I believe this is the service bulletin for it... BMW North America any ways, run this by BMW Toronto and see...
SI B01 02 15
E82 (135i Coupe)
Model Year 2010 produced 8/13/2009 to 2/26/2010
E88 (135i Convertible)
Model Year 2010 produced 7/22/2009 to 2/26/2010
I know when they started showing HPFF issues and the US issued extended warranty and Canada had not they fought for it and got it, not sure if injectors ever worked into that (should have obviously). I suggest calling 2-3 dealers and asking.
http://www.e90post.com/forums/showthread.php?t=586756
See post #7 and #8
E46
Old 02-27-2017, 09:29 AM   #10
Mat135i
My car is a 2008 so this service bulletin doesnt apply to me. I found this recall for my car: http://www.1addicts.com/forums/attac...6&d=1469006040
Hopefully it applies to Canadian customers.
Old 02-27-2017, 11:01 AM   #11
Blackedout95
Ouch 2008, let me make a call....one minute
Alright based on my call to one of the better mechanics at BMW here (close friend) no recall on injectors for 2008, however they were replacing them under warranty if they came in and knew via the injector part number if they were the "bad" ones. Again though, no recall
E46
Old 02-27-2017, 11:14 AM   #12
Mat135i
Ouch, guess its gonna have to come out my pocket, thank you much appreciated .
Old 02-27-2017, 10:02 PM   #13
BmW1819
Could be your injectors too
Old 02-28-2017, 12:13 AM   #14
There was a recall bulletin on them. My father's 2007 335i qualified for them back in 2015, well past his warranty. Maranello BMW did the work.
I'll try and find the work order maybe there's a TSB on there.
Old 02-28-2017, 04:13 PM   #15
Mat135i
Im gonna call Meranello BMW later and see what they say.
