Old 03-23-2012, 06:45 PM   #1
tin-man
Cluster is dead now
My cluster has been givin me issues since I bought the car. It is a '94 318is. The cluster has been turning off and on intermittently. I have tried another cluster but the issue persists on the replacement cluster. I have traced it to fuse 23. When I pull fuse 23, the cluster is off just like the issue.
I have read on a UK forum that the ignition switch may be the issue.
I have read lots about this issue but no one has followed up with their resolution.
Has anyone successfully repaired this problem, not including replacing the cluster.
tin-man is offline   Reply With Quote
Old 03-24-2012, 07:32 AM   #2
E36is
'OldSchool..'
E36is's Avatar
^^ take out cluster, then make sure all ground bolts are tight and clean from oxidation.
E36is is online now   Reply With Quote
Old 04-02-2012, 08:50 PM   #3
someguy
Singhy
Also check out the wiring in the trunk on the left hand side. There is a common issue with wiring being shredded inside the rubber casing causing shorts. However, this usually results in a blown fuse, so it may not be the case.
someguy is offline   Reply With Quote
