Old 12-14-2003, 05:28 AM   #1
RigsPGT
Noise while in WOT
Hi everyone!
As you can see im a Newbie here and i dont know as much BMW stuff as you guys do since i barely drive the IX.
Anyway, to start off, everytime i go in full throtle i would hear a grinding noise coming from the transmission or its related parts. The noise would stop right away as soon as i let off the gas. it sounds like a jet though starting from a low pitch to a high one (depending on the rpms).
Does anyone know or have the same problem? Everything works great tho its just the noise that bothers
Thanks, Rigert
White 89-325ix (winter snowmobile)
Red 1994 Probe GT, KLZE engine, DXD clutch, AWR MMs, Eibachs, Hot Shot Headers +CAI, 2.5" Exhaust with Magnaflow HF converter, 65mm TB, 12" front rotors with Hawk pads, X drilled Brembos, Sleepy eye projectors, kenwood sound.
T3T04E in progress
Got to love 5psi on a 200HP N/A engine
RigsPGT is offline   Reply With Quote
Old 12-14-2003, 05:30 AM   #2
crazyvadim
crazyvadim's Avatar
Send a message via AIM to crazyvadim
This happens in every gear??
crazyvadim is offline   Reply With Quote
Old 12-14-2003, 05:39 AM   #3
SebSter
SebSter's Avatar
is it like a whistling sound? cause i kinda get that too, i think it might be from a dying tranny/differentials... not sure tho
Old car 1990 325ix. Current car 2000 540i.
SebSter is offline   Reply With Quote
Old 12-14-2003, 05:46 AM   #4
RigsPGT
I would say when going above 30mph but not sure, I just need to test drive it again and record everything cause i barely use the beamer (only in snow time).
T3T04E in progress
Old 12-15-2003, 09:11 PM   #5
325iSBimmer
///MMMM VIDA
325iSBimmer's Avatar
could possibly be your throw out bearing...but that should make more of a noise when you push the clutch in.
UNDER CONSTRUCTION
