Old 01-12-2017, 07:47 AM   #1
El Gato Liso
El Gato Liso's Avatar
E46 330i Supercharged looking for more boost in stock engine...water meth inquiry
Hey all!
My e46 is charged with a 6psi pulley. I was thinking of grabbing a smaller pulley to aim for roughly 9-psi.
My engine is currently stock and non intercooled. I was thinking of adding a water meth kit to allow safe operation of the higher boost, without intercooling or engine modification.
My question is...how does water/meth kit work along side tuning? I know some may be boost operated...
I'm really trying to wrap my head around the tuning aspect with water/meth. So far all I can think is once X boost is reached, water/meth then comes on and sprays away while boost increases...and ecu is tuned to do its thing with the higher boost, as per normal.
What if the water/meth runs out? Can the ecu be tuned to cut out at X rpm to prevent boost from increasing?
Thanks for any help folks!
-Rob
R.I.P. E30
Old 01-12-2017, 08:01 AM   #2
Dinanstu
I have never heard of any tunes for the 330 to do what you want, unfortunately.
There are a lot of tunes for the E 36 M3, so perhaps Karl an active out of work might have something for you…
Old 09-19-2017, 07:40 AM   #3
sleemalax
I recently came across your blog and have been reading along. I thought I would leave my first comment. I don't know what to say except that I have enjoyed reading. Nice blog. I will keep visiting this blog very often.voyance telephone
sleemalax is offline   Reply With Quote
Old 09-25-2017, 09:54 AM   #4
sleemalax
Nice Informative Blog having nice sharing..find junkyards
Old 07-18-2018, 02:26 AM   #5
vehiclemech
What kind of super charger are you running?
Active Autowerke, VF Engineering?
vehiclemech is offline   Reply With Quote
Old 07-18-2018, 09:50 PM   #6
El Gato Liso
I?m usign VF engineering kit with a vortech blower! I?m using the V2 version
R.I.P. E30
Old 07-19-2018, 03:25 AM   #7
vehiclemech
Your ECU definitely needs to be tuned in order to take full advantage of the meth injection
Here’s a common kit used amongst bmws
https://www.ecstuning.com/b-aem-elec...n-kit/30-3000/
From my understanding meth injection works via throwing in more cool air and decreasing combustion temperatures which results in more power.
The kit comes with a controller that lets you set at what rpm and boost should the injection happen.
Here’s a link explaining what it is and how it works
https://youtu.be/HkPFZWd8wj4
