02-02-2013, 12:55 AM
Car: E36 325is
transmission whistle???
i have a bmw e36 325is (m3 swap from 98), i just had a small leak fixed on my transmission, and had a new hanger bearing installed aswell (completely shredded). From a cold start, in all the gears i heard a whistling noise coming from my transmission, but when i clutch in, the noise stops. it seems to occur when under load. When my car is fully warmed up the noise stops. i did some research and no solid explanations. before i got everything fixed it never had made that noise.
has anyone had this problem?
thanks,
02-02-2013, 05:55 AM
'OldSchool..'
Car: .
few things come to mind:
need a new clutch/flywheel
need a new throw out bearing
02-02-2013, 10:40 AM
Car: E36 325is
okay, ill defiantly look into that.
02-02-2013, 10:54 AM
Car: E36 325is
could it possibly the type of fluid used aswell? my clutch seems fine, not slipping or anything. because once my car is warmed up it goes away..
02-02-2013, 11:34 AM
'OldSchool..'
Car: .
dont think fluid will cause that noise.
02-02-2013, 12:07 PM
Car: E36 325is
i was reading on m3forum.net, and it could possibly be an input shaft bearing.
02-02-2013, 01:34 PM
überwacht Sie
Car: (OO=[][]=OO)
Judging by your symptoms my number one suspect would be the input bearing on the diff.
Seen this issue quite a few times.
Officer Douche Bag: " you know, I should give you a ticket for your exhaust being so loud"
Me: " In that case, shouldn't you be ticketing every Harley motorcycle you come across, surly they are louder then I am ? "
Officer Douche Bag: "Oh no, they came from the factory like that, it's obvious you modified your exhaust to make it louder, here is your ticket"
Me: "Have a great day officer"
02-02-2013, 04:49 PM
Car: E36 325is
im probably going to call RMP and have them diagnose this problem.
02-03-2013, 11:00 AM
Hatters gon Hatt
Car: 318is roadtriper
clutchy
02-03-2013, 11:33 AM
#10
Car: E34 M5 Euro
Input shaft bearing on the tranny. Get M0S2 Anti-friction paste for gears by Lubro Moly, squize it into the tranny and the noise will go away.
1990 M5 Euro
02-03-2013, 11:54 AM
#11
Car: E36 325is
Where can you get this paste???
02-03-2013, 01:54 PM
#12
Car: 1995 325is
Definitely bearing, I had the exact same problem. Mine was the counter shaft bearing though. Do you hear the noise in 5th gear?
02-03-2013, 02:19 PM
#13
Car: E36 325is
yes i did, in all the gears. i have another transmission that i got earlier this week, if it comes down to it, ill just have the other one swapped out.
02-04-2013, 12:32 PM
#14
Car: E34 M5 Euro
you can buy the paste at Automaster Trading shop. It's on 1170 Sheppard ave West, Unit 27. It's like 10-15$
1990 M5 Euro
