Old 05-04-2010, 01:41 PM   #1
Gamite
Gamite's Avatar
Looking to buy a 5 series, look here
E34: 1989 to 1995
Pre-Facelift 1989-1993
- 1989 -1991 came with US Spec projector headlights
- 1993 gets updated mirror style
Facelift 1994 - 1995
- All years came with US spec projector headlights
- Wider grill, M5 Side skirts
- Available models: 525i (2.5L M50), 530i (4.0L M60), 540i (4.0L M60)
- Interior door panels updated
Special Models
M5 - 1989-1992?
M540 - 1995 - This was a special edition that came to Canada instead of the M5, look for the plaque that will state which number out of 132 cars came.
Available options to look for
- Drop Down seats
Things to look for
- Rust at the bottom of the doors
- Thrust arms rattle, causing vibrations at 55mph (88km/h)
- M60 motors suffer from nikalsil problems, lower quality gas ate away at the sleeves of the cylinders, the engine should go for a compression check before purchasing.
- M60 - power steering leaks, driver's side motor mounts, valley pan gasket (mysterious coolant leaks), timing cover gaskets, valve cover gaskets, rear main seal
- M60 Oil pump bolts/mounting nuts notoriously rattle loose and end up in laying in the pan.
E39: 1996 to 2003
Pre-Facelift 1996 - 2000
- Available models: 528i (2.8L M52), 540i (4.4L M62)
Facelift 2001 - 2003
- Available Models: 525i (2.5L M54), 530i (3.0L M54), 540i (4.4L M62)
- Updated headlights/taillights
- Updated steering wheel
Special Models:
- M5 (Headliner was upgraded from black felt to alacantera for the facelift as well as updated cluster steering and steering wheel.)
Things to look for:
- M62 motor mounts tend to leak and get soft, this causes the rad neck to crack and eventually break off.
- LCD pixels in the lower display in the cluster almost always go, this is a very common occurance in E39's.
E60: 2004 to current
F10: Future
Feel free to add to this list, I will add them as you guys go along.
www.gamite.net
Old 05-04-2010, 03:59 PM   #2
Nick_V
Nick_V's Avatar
E34 M60 - power steering leaks, driver's side motor mounts, valley pan gasket (mysterious coolant leaks), timing cover gaskets, valve cover gaskets, rear main seal, lol etc.... can be expensive and a bitch to fix all that crap so make sure you know what's been done, cause if not, these things WILL leak eventually.
Old 05-04-2010, 05:52 PM   #3
Gamite
Gamite's Avatar
are these problems specific to you, or do you know for a fact that it will happen to most cars?
Every BMW power steering leaks, so I didn't put that in.
www.gamite.net
Old 05-04-2010, 06:31 PM   #4
Nick_V
Nick_V's Avatar
yes, all of these are well documented as being specific M60 problems.
Old 05-04-2010, 06:35 PM   #5
Nick_V
Nick_V's Avatar
I forgot a really important one that's also M60-specific: Oil pump bolts/mounting nuts notoriously rattle loose and end up in laying in the pan. This definitely happens to most cars...
Old 08-15-2011, 09:00 AM   #6
JJJames
JJJames's Avatar
Correct me if I'm wrong, but I'm pretty sure there were only 32 M540's imported into Canada - not 132, making it one of the rarest out there.
JJJames is offline   Reply With Quote
Old 08-15-2011, 11:32 AM   #7
Correct.
Old 08-21-2011, 03:27 PM   #8
RF535i
FYI , the latest Bimmer mag has a great article on buying a used E60.
good thing I already read up on most things before buying my CPO 535i
RF535i is offline   Reply With Quote
Old 01-07-2013, 02:27 PM   #9
trunks
Look at this site for diff parts: http://www.parts4euro.com/DCShop/ind...fd50ae3b941552
trunks is offline   Reply With Quote
Old 04-05-2013, 07:06 PM   #10
royst
Hope someone can shed some light on this. I was looking at a E34 and I noticed on the back it said AC Schnitzer. My google search has come up empty.
royst is offline   Reply With Quote
Old 05-07-2013, 11:55 AM   #11
VighJ
And only 16 were 6 spd Manual, and I have one of those 16
VighJ is offline   Reply With Quote
