Old 11-14-2012, 11:37 AM   #136
kenmar
Originally Posted by nate_s89 View Post
Yeah its been done more then enough times. Just depends on how low/stiff I want to go. Probably will end up with 235/40 and 225/45. Fenders are already rolled, and if need be I will head over to stance factory and get them pulled as well.
Curious how 225/45 and 235/40 looks if that's what you settled on. I was toying with the same f/r combo but finally went with 225/45 and 235/45 (slightly taller) because the 235/40 is slightly lower and the rear is already lower with my H&R Sport setup. Plus, 235/40 tires have limited selection and are pricey.
kenmar is offline   Reply With Quote
Old 11-15-2012, 12:39 AM   #137
nate_s89
Originally Posted by cormier View Post
Heard good things about the WAR chip-- especially if you're doing a lot of tuning. That cost at turner would get way too much for not enough potential
I think that's the only option on the market -- unless you get into standalone systems or MS, etc
Good to hear, so far haven't had any negative feedback about it so I think I am going to go that route.
I have an MS system from a previous build but am not up for going standalone with this one I don't think.
Old topic, but did you ever get your temper gauge sender mounted in the head? I ended up cutting and tapping the fitting that was in their after messing around with adapters.
I ended up going with 245/40 and 224/45 and I leveled everything out with the different sized spring pads in the rear. I will snap a pic.
I have the H&R OE sport setup and had the same issue with the rear being lower.
nate_s89 is online now   Reply With Quote
