11-11-2012, 06:17 PM
all by chance...
Car: 91 318i
Water under batt tray in trunk...
I drained the water from that plug under the car... When i removed the battery to dry the remaining water i noticed that there was a tube connected to the drain plug.. But where does this connect to?
Any ideas?
11-11-2012, 06:18 PM
Car: God's Chariot
It's supposed to be for that overflow port on the side of the battery.
11-11-2012, 07:53 PM
all by chance...
Car: 91 318i
Any idea where that water is coming from that stands under the batt tray?
11-11-2012, 07:59 PM
Car: 87,325IS - E36 M3
Sunroof drain?? That looks like the battery vent hose
11-11-2012, 08:39 PM
all by chance...
Car: 91 318i
How can i check if it is the sunroof drain?
11-11-2012, 10:23 PM
Car: 87 325is
open your sunroof and pour some water down the back drain and see if it leaks into the battery tray. Could also be a leaky taillight gasket, or there is a grommet above the battery tray where your sidemarker light wire exits the car.
11-11-2012, 11:32 PM
all by chance...
Car: 91 318i
^^^ thanks.. Ill give it a try
11-12-2012, 03:36 PM
Car: E30 318is Arctic Rot
Might be the flap vent from the trunk to inside the rear bumper, thats where the sunroof drain should be if it's connected properly. It could also be your trunk seal, mine leaks a bit into the battery area when I wash the car or park nose down in the driveway.
11-15-2012, 07:49 PM
Sun roof drains is a black hose that goes into that vent behind the bumper
11-15-2012, 08:08 PM
#10
all by chance...
Car: 91 318i
Thanks for all the info!
Im going to do some water tests this weekend after i fix my oil leak by the oil filter canister and the block. Very common on the m42 it seems
11-15-2012, 08:25 PM
#11
Last of the Late-Brakers
Car: 1992 M5
Connect the battery vent too! Acid from an unvented battery will rust your shit faster than a puddle of water ever would...
04-04-2013, 09:32 AM
#12
all by chance...
Car: 91 318i
So it turned out to be the gasket around the passenger side rear tail light. It wasn't seated properly.
04-10-2013, 08:09 PM
#13
Nice u silcone it?
04-10-2013, 08:58 PM
#14
all by chance...
Car: 91 318i
Originally Posted by BmW1819
Nice u silcone it?
No.. The rubber seal around the tail light was not seated properly. I reinstalled the rubber properly and took care when reinstalling the tail light to the car. Did a leak test with my hose and it was dry. The past few days i left my car out in he rain... So far atill dry
04-11-2013, 08:10 PM
#15
Ahhh nice
