Old 11-03-2012, 07:55 PM   #1
iverson03tj
mishimoto radiator fitment issue
So i got a the aluminum rad and i tried everything but it just doest fit like the oem rad? the fan shroud doesn't fit properly and the radiator it self sticks out about 1/2 an inch higher than usual... Has anyone else had this problem?
e30 325ic -
PREVIOUS CARS
'01 Audi A4 B5
'96 Civic B16
'95 Acura Legend Type II
'97 Euro Estroil E36 M3 Vert
iverson03tj is online now   Reply With Quote
Old 11-03-2012, 08:08 PM   #2
Check the bottom mounts and see if the metal lip on the rad is binding anywhere?
Old 11-03-2012, 09:15 PM   #3
kenmar
My first mishi had that problem. I spent more than half an hour using a file to remove excess aluminum so that the shroud fit properly. While you're doing this, it's critical to ensure even clearance around the fan blade perimeter with the shroud, otherwise you're asking for catastrophic failure.
My first mishi lasted 3 years before it sprung the well-known pin hole leaks. Not catastrophic, but a failure nonetheless. My warranty replacement mishi did not have the fan shroud mounting issues but did have another fitment issue: the overflow nipple was soldered on too close to the upper hose nipple. Consequently, I could not put the hoses on because of clearance issues. I wound up using a propane torch to heat it up and bend the overflow nozzle so i could get the friggen hoses on.
These rads are never a direct bolt on!
