Old 09-02-2010, 11:16 PM   #16
agentM
Detailer, tint, Chipguard
agentM's Avatar
Well, I went under the car and check all the pipe connection and tighten it more and now its working fine. I'm getting 8 boost and when the weather is cool I get 9 sometimes.
agentM is offline   Reply With Quote
Old 12-02-2010, 11:47 PM   #17
iverson03tj
Im new to these things, wo how do you know if there is a leak at all? like without checking for anything.
>>>>WTB: Clean Estroil e36 Shell!! Pm me!<<<<
---------------Work In PROGRESS---------------
e30 325ic -
e36 328is - * Winter Mode *M50 Mani, 3.23 LSD, M3 Brakes, Intake, Spal fan, poly RTABs, Eibach Swaybars, Koni.
PREVIOUS CARS
'01 Audi A4 B5
'99 Integra Type R t3/t4 Turbo
'96 Civic B16
'95 Acura Legend Type II
'97 Euro Estroil E36 M3 Vert
Old 12-03-2010, 07:19 AM   #18
agentM
agentM's Avatar
You won't get a maximum boost when it leaking.
Old 01-27-2011, 06:15 PM   #19
uzi577
RUNING BOOST
uzi577's Avatar
It will be running below the spec, you should get either abnormal behavior, it will also trip CEL. Do remember the vacuum is very important to run engine. For OBD2 car it does anyway!
uzi577 is offline   Reply With Quote
Old 08-01-2012, 01:27 PM   #20
kevin325
AMG ETR
kevin325's Avatar
I have a vacuum leak on a S/C car - where would i block off in order to smoke test the system to find the leak?
kevin325 is offline   Reply With Quote
Old 10-09-2012, 04:39 PM   #21
uzi577
RUNING BOOST
uzi577's Avatar
Mine was intercooler hairline crack. So what the shop did first troubleshooted from to intake to intercooler, then intercooler itself, then pluming from intercooler to manifold. I think it was the easiest way to do it.
Originally Posted by Mr_Bimmer View Post
....., Naturally aspirated is the expensive way to go slow.
Old 10-21-2012, 02:10 AM   #22
BMWdouche
Not Banned... Yet
BMWdouche's Avatar
Get in touch with my boy Jon at Bimmersport and he'll do your smoke test for ya.. under $100
BMWdouche is offline   Reply With Quote
Old 10-21-2012, 07:10 AM   #23
Dinanstu
Exactly...get it done right, thats the place to go..I just did the same thing last week....
Old 01-17-2013, 02:04 PM   #24
RMPMOTORS
RMPMOTORS's Avatar
We do smoke tests also!
Call for any services you may need.
Eibach-Koni-Bilstein-H&R-Powerflex-KW Suspension-OEM Parts+ MORE
EUROPEAN AUTO SERVICE & PERFORMANCE
www.RMPMOTORS.com
www.Facebook.com/RMPMotors
RMPMOTORS is online now   Reply With Quote
