Old 08-23-2012, 11:53 PM   #1
xsherix
E30 questions for pre buy
Hey guys. I'm looking at getting an e30, are there any specific problems I shoul look for? Anyone know of
Any good deals on an e30?
xsherix is offline   Reply With Quote
Old 08-24-2012, 07:48 AM   #2
defaultName
Rust!!!
defaultName is online now   Reply With Quote
Old 08-24-2012, 09:52 AM   #3
InfiniteDice
12 Years with the E30
InfiniteDice's Avatar
Rust under the front lift points (behind the front wheel well. Rust above the rear license plate, around the plate lights. Rust on the rockers just ahead of the rear wheels. Rust in the battery tray area or the other side of the trunk where the jack goes. Bottom of doors. Sunroof rust - 70 - 100$ for a used replacement.
Another good thing to do is smell the carpet, and feel the carpet, if you feel moisture, you are almost guaranteed to have rust/holes under there.
The Rockers and the front lift points can be car killers, simply because people can't afford or don't have the time or tools to do it themselves. Skip these cars unless for parts, or if it's an extremely rare model.
If you see surface rust on the fenders hood or little dents here or there it's nothing to worry about, make note of them for adjusting the price but.
Remove the oil cap, check for a greenish tinged crud. A little white goo isn't bad that happens. remove coolant overflow cap, look for oil floating or at the bottom of the overflow container.
Run the car. note idle stability between 1100 and 750... depending on the temps.
Listen to the engine, the ticking is normal but listen for any offbeat ticks or knocks.
If it's manual shift in in and out of each gear, many linkages are old so if it's really wobbly you may need to put some money into it, just make sure it shifts.
Automatic - pray to the bimmer gods.
Check for brake pressure. From the outside of the car check the brake disc surfaces for heavy scarring or uneven wear, could mean a bad caliper.
Check all the power windows and the sunroof.
I could go on but generally if it drives at least as well as an older car, and there isn't rust holes in the rockers or the front jack points, then consider buying it.
Old 08-24-2012, 10:03 AM   #4
InfiniteDice
Oh and don't skip the early models because of the 'diving board' bumpers. Not having to pass emissions more than makes up for bumpers you can fix or change out later.
Old 08-24-2012, 12:12 PM   #5
+1 they look great swapped out and you may even grow to like them
There's a ton of great e30 deals going on -- check in the FS section here, kijiji and autotrader for more
Old 08-24-2012, 07:28 PM   #6
MikeDsantos
i am also looking for an e30 and Every single one i have went to see so far will look clean from the body but under it is just full of Rust so look out for that never judge a book by its cover
MikeDsantos is offline   Reply With Quote
Old 08-24-2012, 09:05 PM   #7
out your way there may be no rust because they don't use salt there. but just in case. as mentioned the rust. 20+ year old body so expect some repair.
mechanical: timing belt waterpump service.
control arms and bushings
emerg brakes and kit
Just be prepared to spend money on one that is in good condition. If it is mint then you will most likely pay a premium.
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
Ceeker is online now   Reply With Quote
