Old 06-19-2012, 06:47 AM   #1
DET1990
front sway bar mounting
the swaybar mount on the passenger side of my 328 is gone is there a bracket kit that can be bought so i can have it welded in
to be more specific im talking about the part of the sway bar that mounts to the frame not to the suspension
DET1990 is online now   Reply With Quote
Old 06-19-2012, 11:37 AM   #2
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
Thanks tips.
I welded new ones in when my motor was out. Would be much more difficult with it in to grind out the spot welds.
Old 06-20-2012, 09:13 AM   #3
Lang75
220 Kph, E39 on Autobahn
I have had both of mine replaced, the last one the fellow used some C channel over the existing mount after grinding it down and drilled new holes to mount the bracket to. Both were welded in without the removal of the engine.
Lang75 is offline   Reply With Quote
Old 06-20-2012, 08:18 PM   #4
DET1990
any idea where i can get it done and how much did it run you
Old 06-20-2012, 08:20 PM   #5
Blackedout95
I had it done on my old e36 as well, motor in too. I had a local body shop do it that does work for the garage, it was 5 years ago now but they charged me like $200 or something.
E46
Old 06-21-2012, 05:30 PM   #6
5style
Hatters gon Hatt
5style's Avatar
wierd, i did my bushings, mine are in mint shape
Old 06-21-2012, 10:06 PM   #7
BmW1819
dealer sells them cheap
Old 06-22-2012, 10:55 AM   #8
Axxe
Axxe's Avatar
^+1. I got mine from Maranello for cheaper than most people wanted for cut-offs from a scrap car. It's a pain to do it right with the motor in, the guys that did my car before I got it did a mickey mouse job. Rabbit shit welds and left half the old bracket on the frame rail. I had to carefully cut it off properly, remove the spot welds, and giver a nice bead all the way around on the engine side ONLY which is how the factory does it. Then you hit the wheel well side with a bead of seam sealer or silicone to keep the salt spray from entering and sitting inside the pocket, which causes the rust.
Yes, I'm OCD with structural parts.
Old 06-24-2012, 06:46 AM   #9
DET1990
i got it done at a body shop when i went to the dealer the guy at the parts counter had no idea what i was talking about he said they dont have anything like that but its all done now
Old 06-26-2012, 10:24 PM   #10
MANDD
Autobahn East
Sway bar mount
Not terribly difficult to do, you will need BMW P/N 41 11 8 151 121 Left or 41 11 8 151 122 Right.
Mark.
Old 06-28-2012, 11:08 AM   #11
tehskeo
CEL Magnet
tehskeo's Avatar
Had mine done about a year and a half ago. Only the drivers side needed doing (got ripped off after a hard turn) and it was rusted to bits. Passenger side is original and looks mint. I think it has to do with where the frame drains rainwater. Sometimes it can get clogged and water just sits in the mount.
Part cost me something like $15 and labour was around $130 at a body shop.
tehskeo is offline   Reply With Quote
Old 07-18-2012, 10:01 AM   #12
limenuke
Do these prices include people removing your end links and disassembling everything? Or did you drive the car into the shop with the sway bar unmounted from the car already?
I have a rusted driver's side mount but I've not gotten around to it since the quotes I'm getting are something like 250 for labour and 75 for the part.
Old 07-18-2012, 01:46 PM   #13
MANDD
Autobahn East
Sway Bar Mount
Yes, these prices would include disassembly and refitting.
Mark.
