Old 06-22-2012, 12:26 AM   #1
Pedro
E36 Sweaky Steering Column
Does anyone know how to correct a Sweaky Steering Column on a high milage E36? Sometimes it also stiffens up when turning and the return is not that swift.
Pedro is offline   Reply With Quote
Old 06-22-2012, 05:12 AM   #2
Stance is Gay.
There is a spring on the shaft right by the brake booster. You need to grease it up. Either use some spray lube, or if you can reach your hand down there, use some grease.
It can be hard to get to. Looks like this:
Old 06-26-2012, 09:34 AM   #3
NOTORIOUS VR
NOTORIOUS VR's Avatar
I'm confused, you say it's by the brake booster but that diagram looks like the steering column where the wheels attaches to.
Either way I have the same issue (the squeaking not the binding) and it's freaking annoying... in my situation it's def coming from right behind the wheel, I'm going to have to take that C lip off and try to lube it all up... lubing it with that assembly together didn't do shit for me.
E36 · VEMS · TUNING
Google Talk: NOTORIOUS VR
NOTORIOUS VR is online now   Reply With Quote
Old 06-26-2012, 09:37 AM   #4
Stance is Gay.
Don't take anything inside apart.
The squeak always sounds like its directly behind the steering wheel but it comes from the firewall area. I know it's really hard to believe.
Old 06-26-2012, 12:38 PM   #5
NOTORIOUS VR
wow... ok.. are you talking in the engine bay by the booster or on the inside of the firewall?
E36 · VEMS · TUNING
Old 07-04-2012, 11:04 PM   #6
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
^ Yeah, engine bay side. Bottom of the steering column. Mine started squeeking again, lasted 40k squeek free, and I just sprayed it with lithium grease in a can. Going to try waxed chain lube next, should repel the dirt and keep the squeak away longer.
Old 07-05-2012, 07:14 AM   #7
sproule905
sproule905's Avatar
Make sure the parts are warm before. I moto and all chain wax requires warm parts to adhere to
Old 07-05-2012, 02:21 PM   #8
Axxe
Axxe's Avatar
^ Really? I use chain wax on my bicycle and have always used it cold (no real way to heat up the chain appreciably unless I baked it). Maybe I'll just throw the needle on the grease gun and jam it up there and give it all the graphite grease it can take. Such a PITA issue.
Old 07-05-2012, 04:00 PM   #9
sproule905
sproule905's Avatar
Probably overkill that it would fling off in your application. And also on the bicycle. Think of the rpm's a motocross bikes chain endurs. I've just noticed from a motocross POV, if it's cold, it will just fling off
Old 07-06-2012, 06:55 PM   #10
MANDD
Autobahn East
Steering Shaft
Squeak noise, stiff when turning? Sounds like the U joint (seized) on the steering shaft, quite common.
This is fitted in the engine compartment from firewall to rack.
BMW 32 31 1 159 866
Mark.
